The caster wheels I bought a while ago do not rotate smoothly. It is rough and sometimes catches, especially when compared to the casters (other brand, which is significantly smoother) I have used previously. Is there any way to make the bearing rotate smoother?
This is the one I am talking about: https://www.adafruit.com/product/2942
robot car caster wheel does not rotate smoothly
- adafruit_support_carter
Re: robot car caster wheel does not rotate smoothly
Those are pretty simple. Just a plastic wheel on a metal axle. So there could be some stiction between the wheel and the axle.
What are you using them on? How heavy is it?
- T_Mo
Is the issue with the rotation of the caster on the base plate, or the rotation of the wheel around its axis?
