Arduino IDE version : arduino IDE 2.3.4
I followed the steps as mentioned https://cdn-learn.adafruit.com/download ... -board.pdf. But while uploading the neopixel example, its giving me an error.
loading library from c:\Users\user\Documents\Arduino\libraries\user_tinygsr: invalid library: no header files found
FQBN: espressif:esp32:adafruit_qtpy_esp32c3
Using board 'adafruit_qtpy_esp32c3' from platform in folder: C:\Users\user\Documents\Arduino\hardware\espressif\esp32
Using core 'esp32' from platform in folder: C:\Users\user\Documents\Arduino\hardware\espressif\esp32
cmd /c if exist "C:\\Users\\user\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2025030-2908-1nyvh46.066vg\\sketch_jan30a\\partitions.csv" COPY /y "C:\\Users\\user\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2025030-2908-1nyvh46.066vg\\sketch_jan30a\\partitions.csv" "C:\\Users\\user\\AppData\\Local\\arduino\\sketches\\FBFF06F9553862E3A095B19ADAEB73B5\\partitions.csv"
cmd /c if not exist "C:\\Users\\user\\AppData\\Local\\arduino\\sketches\\FBFF06F9553862E3A095B19ADAEB73B5\\partitions.csv" if exist "C:\\Users\\user\\Documents\\Arduino\\hardware\\espressif\\esp32\\variants\\adafruit_qtpy_esp32c3\\partitions.csv" COPY "C:\\Users\\user\\Documents\\Arduino\\hardware\\espressif\\esp32\\variants\\adafruit_qtpy_esp32c3\\partitions.csv" "C:\\Users\\user\\AppData\\Local\\arduino\\sketches\\FBFF06F9553862E3A095B19ADAEB73B5\\partitions.csv"
cmd /c if not exist "C:\\Users\\user\\AppData\\Local\\arduino\\sketches\\FBFF06F9553862E3A095B19ADAEB73B5\\partitions.csv" COPY "C:\\Users\\user\\Documents\\Arduino\\hardware\\espressif\\esp32\\tools\\partitions\\default.csv" "C:\\Users\\user\\AppData\\Local\\arduino\\sketches\\FBFF06F9553862E3A095B19ADAEB73B5\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\user\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2025030-2908-1nyvh46.066vg\\sketch_jan30a\\bootloader.bin" ( COPY /y "C:\\Users\\user\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2025030-2908-1nyvh46.066vg\\sketch_jan30a\\bootloader.bin" "C:\\Users\\user\\AppData\\Local\\arduino\\sketches\\FBFF06F9553862E3A095B19ADAEB73B5\\sketch_jan30a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\user\\Documents\\Arduino\\hardware\\espressif\\esp32\\variants\\adafruit_qtpy_esp32c3\\bootloader.bin" ( COPY "C:\\Users\\user\\Documents\\Arduino\\hardware\\espressif\\esp32\\variants\\adafruit_qtpy_esp32c3\\bootloader.bin" "C:\\Users\\user\\AppData\\Local\\arduino\\sketches\\FBFF06F9553862E3A095B19ADAEB73B5\\sketch_jan30a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\user\\Documents\\Arduino\\hardware\\espressif\\esp32/tools/esptool\\esptool.exe" --chip esp32c3 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\user\\AppData\\Local\\arduino\\sketches\\FBFF06F9553862E3A095B19ADAEB73B5\\sketch_jan30a.ino.bootloader.bin" "C:\\Users\\user\\Documents\\Arduino\\hardware\\espressif\\esp32\\tools\\esp32-arduino-libs\\esp32c3\\bin\\bootloader_qio_80m.elf" ) )
The system cannot find the path specified.
exit status 1
Compilation error: exit status 1
