Hey all I'm fairly new to this but I believe I am following all instructions correctly, beginning to suspect a faulty sensor.
I am trying to read rotation data from a BNO085 breakout using the RadioFruit RFM95. I believe I have connected them correctly; Solder bridge over PS1, SCL to Tx, SDA to Rx, GND to GND, and 3v to Vin.
I am using PlatformIO as my IDE, and I successfully installed the Adafruit unified sensor, BusIO, and BNO08x libraries. I have my baud rate set to 115200, and I am attempting to use the rotation_vector example from the BNO library. I have commented out the I2C line and un-commented the UART line. (I also had to add a function prototype for setReports() as the original example was attempting to use the function without declaring it). The program uploads without issue, but always returns "Failed to find BNO08x chip" in the serial monitor.
In the past I have successfully used a different BNO085 module for another project also using PlatformIO, but unfortunately I gave that project to someone else so I cannot troubleshoot with a known good sensor.
I have also tried to run the sensor in SPI and I2C modes (with proper wiring and mode select jumpers soldered) to no avail. Any help at this point would be massively appreciated.
Feather M0 RFM95 not detecting a BNO085 over UART
- SpearFlight
- adafruit_support_carter
Re: Feather M0 RFM95 not detecting a BNO085 over UART
That is correct for setting UART mode (not UART RVC).Solder bridge over PS1
https://learn.adafruit.com/adafruit-9-d ... ns-3072339
So that seems OK.
This also seems correct per the pinout page:SCL to Tx, SDA to Rx, GND to GND, and 3v to Vin.
https://learn.adafruit.com/adafruit-9-d ... ns-3072625
This might be a platformio thing. Arduino generally takes care of the prototypes as part of its automagic stuff.I also had to add a function prototype for setReports() as the original example was attempting to use the function without declaring it
Might be a connection issue of some kind. Please post a photo of the setup showing how everything is connected.The program uploads without issue, but always returns "Failed to find BNO08x chip" in the serial monitor.
- SpearFlight
Here are photos of the front and back showing wire connections and solder bridges. Also shows BNO is properly receiving power (green LED)
Thanks for the lightning response!
- IMG_1632.jpeg (482.65 KiB) Viewed 36 times
- IMG_1634.jpeg (442.56 KiB) Viewed 36 times
The serial mode on the BNO085 has a weird baud rate requirement. It looks like this known and it may not work with UART on everything:
https://github.com/adafruit/Adafruit_BNO08x/issues/8
Were you attempting UART as a backup to I2C and/or SPI?
If you want to stick with UART, there's also the RVC mode:
https://learn.adafruit.com/adafruit-9-d ... or-arduino
which operates at a more standard 115200 baud. But it only provides a subset of the total sensor information:
- SpearFlight
Not as a backup no, I wanted to avoid using SPI to keep my wiring simple, and there is something on the BNO product page that states it does not operate well over I2C with certain MCUs, so I generally try to avoid I2C for this sensor.
I just tried setting baud rates to 3000000 as suggested, still no dice.
I have managed to get it to work over I2C, so it looks like we’re going with that for now. The BNO product page says I2C works OK with SAMD51 MCUs, any insight on the reliability with M0’s SAMD21 MCU?
