JST-SH 4-pin connector & STEMMA QT colors
Post Reply
aalm
Post by aalm »
Im designing a PCB and Im going to use JST SH 4-pin connectors. Im planning to use your STEMMA QT cables.
I would like to follow your coloring.
Red - 3.3VDC Power
Black - Ground
Blue - I2C SDA Data
Yellow - I2C SCL Clock
I cannot find any reference to what numbers the pins have. I have the footprint attached.
Can you please tell me what color is on what pin.
Thank you very much!
Screenshot 2025-02-04 at 17.39.26.png (84.81 KiB) Viewed 12 times
adafruit_support_carter
Re: JST-SH 4-pin connector & STEMMA QT colors
The STEMMA QT spec is here:
https://learn.adafruit.com/introducing- ... ical-specs
However, be careful with pin numbering. I think the Adafruit created Eagle PCB parts may not follow JST pin numbering order in all cases - so may be reversed.
Carefully looking at a STEMMA QT cable might help:
https://www.adafruit.com/product/4209
And compare that to JST SH spec:
https://www.jst-mfg.com/product/index.php?series=231
Post Reply
