Problem with sleep function code in ESP32
jay_gonzo
Post by jay_gonzo »
Hi All,
I am getting some error in compiling my code for sleep function.
Compiler complaining about bool value. Strange thing this code worked before but now it has errors!
Can someone lend a hand here to solve this? The code is below;
//regards,Jay
void Adafruit_ILI9341::sleep(bool value)
    if (value)
        writeCommand(0x10);         // Send command to put the display to sleep.
        delay(5);                   // Delay for shutdown time before another command can be sent.
    else
        writeCommand(0x11);         // Send command to wakeup the display.
        delay(120);                 // Wait for the display power supplies to stabilise.
ESP32_Master_DishWasher:66:40: error: no 'void Adafruit_ILI9341::sleep(bool)' member function declared in class 'Adafruit_ILI9341'
\Users\jay\Documents\Arduino\ESP32_DishWasher_2022-08-09\ESP32_Master_DishWasher\ESP32_Master_DishWasher.ino: In function 'void setup()':
ESP32_Master_DishWasher:186:7: error: 'class Adafruit_ILI9341' has no member named 'sleep'
tft.sleep(false);
\Users\jay\Documents\Arduino\ESP32_DishWasher_2022-08-09\ESP32_Master_DishWasher\ESP32_Master_DishWasher.ino: In function 'void loop()':
ESP32_Master_DishWasher:494:9: error: 'class Adafruit_ILI9341' has no member named 'sleep'
tft.sleep(true);
mikeysklar
Re: Problem with sleep function code in ESP32
Post by mikeysklar »
Can you post your code or a short reproducible sample that fails to build?
jay_gonzo
Post by jay_gonzo »
Hi, Here is the whole.
The code compiled without errors before but now it has errors.
I do not why..
Added line 14-23
Changed and added line 264 and 279
Led Yellow(LED_Y) is working
Need to fix Alarm_LED_Y to work
2022-01-13
#include "SPI.h"
//#include <Wire.h>
#include <esp_now.h>
#include <WiFi.h>
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
//#include <Adafruit_SSD1306.h>
//#include <Arduino_GFX_Library.h>
#define TFT_SCK    18  //14
#define TFT_MOSI   23  //4
#define TFT_MISO   19  //2
#define TFT_CS     5  //12
#define TFT_DC     16  //2,13
#define TFT_RST    17  //4,16
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCK, TFT_RST, TFT_MISO);
///////////////////////////////////SH1106 display////////////////////////////
//Adafruit_SSD1306 display = Adafruit_SSD1306(128, 64, &Wire);
//#include <Adafruit_SH110X.h>
/* Uncomment the initialize the I2C address , uncomment only one, If you get a totally blank screen try the other*/
//#define i2c_Address 0x3c //initialize with the I2C addr 0x3C Typically eBay OLED's
//#define i2c_Address 0x3d //initialize with the I2C addr 0x3D Typically Adafruit OLED's
//#define SCREEN_WIDTH 128 // OLED display width, in pixels
//#define SCREEN_HEIGHT 64 // OLED display height, in pixels
//#define OLED_RESET -1   //   QT-PY / XIAO
//Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
////////////////////////////////////SH1105 display//////////////////////////
//uint8_t broadcastAddress[] = {0xac,0x67,0xb2,0xcc,0xb3,0x00};
uint8_t broadcastAddress[] = {0x7C, 0x9E, 0xBD, 0xF9, 0xB7, 0xB0}; //Receivers address
//#define BUTTON_PIN_BITMASK 0x200000000 // 2^33 in hex
#define PWR_ON 33   //22
#define PSU_ON 25   //32
#define StartStop 36  //BTN
#define _45min 39     //BTN
#define _1h15 34      //BTN
#define LED_R 26      //27
#define LED_G 27   //14,19
#define LED_Y 14   //12,23
#define IRQ 15     //BTN
#define buzzer 13  //26
#define Alarm_LED_Y 12  //13,20
#define TFT_POWER 35    //25 TFT_LED
RTC_DATA_ATTR int bootCount = 0;
int i, j, x, t = 1, k;
uint8_t data = 0;
bool isPaired;
bool a, f, psu;
long psu_time, work_time;
String success;
    if (value)
    else
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  Serial.print("\r\nLast Packet Send Status:\t");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
  if (status ==0){
    success = "Delivery Success :)";
  else{
    success = "Delivery Fail :(";
// Callback when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
  Serial.println(*incomingData);
  if(*incomingData == 5){
    t = 0;
    digitalWrite(buzzer,HIGH);
    digitalWrite(Alarm_LED_Y,HIGH);
    delay(2000);
    digitalWrite(buzzer,LOW);
    delay(8000);
    digitalWrite(Alarm_LED_Y,LOW);
  if(*incomingData == 9){
    psu = 1;
    psu_time = millis();
void setup(){
  Serial.begin(115200);
  pinMode(PWR_ON,OUTPUT);
  pinMode(PSU_ON,OUTPUT);
  digitalWrite(PWR_ON,LOW);
  digitalWrite(PSU_ON,LOW);
  pinMode(_45min,INPUT);
  digitalWrite(_45min,HIGH);
  pinMode(StartStop,INPUT);
  digitalWrite(StartStop,HIGH);
  pinMode(_1h15,INPUT);
  digitalWrite(_1h15,HIGH);
  pinMode(LED_R,OUTPUT);
  digitalWrite(LED_R,LOW);
  pinMode(LED_G,OUTPUT);
  digitalWrite(LED_G,LOW);
  pinMode(LED_Y,OUTPUT);
  digitalWrite(LED_Y,LOW);
  pinMode(Alarm_LED_Y,OUTPUT);
  pinMode(buzzer,OUTPUT);
  pinMode(TFT_POWER,OUTPUT);
  ++bootCount;
  Serial.println("Boot number: " + String(bootCount));
  //Print the wakeup reason for ESP32
  //print_wakeup_reason();
  if(bootCount == 1){
    esp_sleep_enable_ext0_wakeup(GPIO_NUM_15,1);
    //Go to sleep now
    Serial.println("Going to sleep now");
    delay(1000);
    esp_deep_sleep_start();
    Serial.println("never shows this massage");
  digitalWrite(PWR_ON,HIGH);
  WiFi.mode(WIFI_STA);
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for Send CB to
  // get the status of Trasnmitted packet
  esp_now_register_send_cb(OnDataSent);
  // Register peer
  esp_now_peer_info_t peerInfo = {};
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK){
    Serial.println("Failed to add peer");
    f = 0;
    return;
  }else{
    f = 1;
  Serial.println(f);
  // Register for a callback function that will be called when data is received
  esp_now_register_recv_cb(OnDataRecv);
//  Arduino_ESP32SPI bus = Arduino_ESP32SPI(TFT_DC, TFT_CS, TFT_SCK, TFT_MOSI, TFT_MISO);
//  Arduino_ILI9341 tft = Arduino_ILI9341(&bus, TFT_RESET);
  digitalWrite(TFT_POWER, HIGH); // turn on backlight
  //digitalWrite(TFT_RST, HIGH); // set RS LOW
  tft.sleep(false);
  delay(200);
  gpio_hold_dis((gpio_num_t) TFT_RST);
  gpio_deep_sleep_hold_dis();
  tft.begin();
  tft.fillScreen(ILI9341_RED);
  yield();
  tft.fillScreen(ILI9341_BLACK);
  yield();
  tft.setRotation(1);
  tft.setCursor(5, 20);
  tft.setTextColor(ILI9341_WHITE);
  tft.setTextSize(4);
  tft.println("DishWasher \nTimer\n     by\nNagatronic AB");
  //display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  //display.begin(i2c_Address, true); // Address 0x3C default for SH1106 display
  //Serial.println("OLED begun");
  // Show image buffer on the display hardware.
  // Since the buffer is intialized with an Adafruit splashscreen
  // internally, this will display the splashscreen.
  //display.display();
  delay(3000);
  yield();
  tft.setCursor(5, 5);
  tft.setTextSize(3);
  tft.print("TIMER:OFF"); tft.setCursor(5, 30);
  tft.print("Press IRQ button to wakeup\nPress chosen TIME\nand START buttons\nto start timer");
  // Clear the buffer.
//  display.clearDisplay();
//  display.display();
//  display.setCursor(0,10);
//  //display.setTextColor(SSD1306_WHITE);
//  display.setTextColor(SH110X_WHITE); // For SH1106 display
//  display.setTextSize(1);
//  display.print("\tTIMER:OFF\nPress chosen TIME andSTART buttons to \nstart timer");
  work_time = millis();
void loop(){
  if(millis()-psu_time >= 6000){
    psu = 0;
  if(psu){
    digitalWrite(PSU_ON,HIGH);
  }else{
  //int v = 1;
  if(digitalRead(_45min) == 0 && psu == 1){
  //if(v){
    digitalWrite(LED_G,HIGH);
    i = 46;
    k = 0;
    while(i>=0){
      if(f){
      //if(v){
      if(digitalRead(StartStop) == 0 || a == 1){
      //if(v){
        if(i>=46 && k>=59){
        }else{
        a = 1;
        Serial.println("      timer1:on     ");
        digitalWrite(LED_R,HIGH);
        //delay(800);
        if(i == 46){
          tft.setCursor(30, 30);
          tft.print("TIMER:ON 45 min");
          tft.setCursor(110, 80);
          tft.print("00:45");
          x = 1;
          esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &x, sizeof(int));
          if (result == ESP_OK) {
            Serial.println("Sent with success");
          else {
            Serial.println("Error sending the data");
        if(digitalRead(StartStop) == 0 || t == 0){
        //if(!v){
          t = 1;
          a = 0;
          Serial.println("      timer1:off     ");
          x = 3;
          else {
          delay(1000);
          break;
//      display.setCursor(0,0);
//      display.print("TIMER:ON 45min");
//      display.setCursor(6,20);
//      display.print("00:");
      k--;
      if(k<=0){
        i--;
        if(i == 0){
          k = 1;
        }else{
          k = 59;
        tft.fillRect(110, 80, 100, 60, ILI9341_BLACK);
        tft.print("00:");
        if(i<10){
          tft.print("0");
          tft.print(i);
        }else{
          tft.print(i);
        delay(500);
      }else{
        delay(1000);
    if(millis()-psu_time >= 5000){
      psu = 0;
    if(psu){
    }else{
    delay(1000);
  a = 0;
  if(digitalRead(_1h15) == 0 && psu == 1){
    digitalWrite(LED_Y,HIGH);
    i = 16;
    j = 1;
    k = 0;
    while(j>=0){
      if(f){
        if(i>=16 && k>=59 && j==1){
        }else{
        a = 1;
        Serial.println("      timer2:on     ");
        //delay(800);
        if(i == 16 && j == 1){
          tft.print("TIMER:ON 1hr 15min");
          tft.print("01:15");
          x = 2;
          else {
        t = 1;
        a = 0;
        Serial.println("      timer2:off     ");
        x = 4;
        else {
        delay(1000);
        break;
//      display.print("TIMER:ON 1hr 15min");
//      display.print("0");
//      display.print(j);
//      display.print(":");
      if(i == 0){
        i = 59;
        j--;
      k--;
      if(k<=0){
        i--;
        k = 59;
        tft.print("0");
        tft.print(j);
        tft.print(":");
        if(i<10){
          tft.print("0");
          tft.print(i);
        }else{
          tft.print(i);
        delay(500);
      }else{
        delay(1000);
    psu = 0;
   if(psu){
   }else{
  delay(800);
  if(millis()-work_time >= 15000){
    tft.sleep(true);
    delay(500);
    digitalWrite(TFT_POWER, LOW); // turn off backlight
    digitalWrite(TFT_RST, LOW); // set RS LOW
    gpio_hold_en((gpio_num_t) TFT_RST); // enable hold for the pin
    gpio_deep_sleep_hold_en(); // enable hold in deep sleep
mikeysklar
Thanks. Your code builds for me without error. I selected the Adafruit ESP32 Feather since I don't know what board you have.
Here is my setup with the library versions. What is yours?
| Component           | Version |
| macOS               | 15.2    |
| Arduino IDE         | 2.3.4   |
| ESP32 BSP           | 3.1.2   |
| Adafruit NeoPixel   | 1.12.4  |
| Adafruit Keypad     | 1.3.2   |
Linking everything together...
/Users/sklarm/Library/Arduino15/packages/esp32/tools/esp-x32/2405/bin/xtensa-esp32-elf-g++ -Wl,--Map=/Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.map -L/Users/sklarm/Library/Arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-489d7a2b-v1/esp32/lib -L/Users/sklarm/Library/Arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-489d7a2b-v1/esp32/ld -L/Users/sklarm/Library/Arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-489d7a2b-v1/esp32/dio_qspi -Wl,--wrap=esp_panic_handler @/Users/sklarm/Library/Arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-489d7a2b-v1/esp32/flags/ld_flags @/Users/sklarm/Library/Arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-489d7a2b-v1/esp32/flags/ld_scripts -Wl,--start-group /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/sketch/snap-apart-super-debug.ino.cpp.o /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp.o /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/libraries/Adafruit_NeoPixel/esp.c.o /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/libraries/Adafruit_NeoPixel/esp8266.c.o /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/libraries/Adafruit_NeoPixel/kendyte_k210.c.o /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/libraries/Adafruit_Keypad/Adafruit_Keypad.cpp.o /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/core/core.a @/Users/sklarm/Library/Arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-489d7a2b-v1/esp32/flags/ld_libs -Wl,--end-group -Wl,-EL -o /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.elf
/Users/sklarm/Library/Arduino15/packages/esp32/tools/esptool_py/4.9.dev3/esptool --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.bin /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.elf
esptool.py v4.8.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
python3 /Users/sklarm/Library/Arduino15/packages/esp32/hardware/esp32/3.1.2/tools/gen_esp32part.py -q /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/partitions.csv /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.partitions.bin
/usr/bin/env bash -c "[ ! -d \"/Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA\"/libraries/Insights ] || python3 \"/Users/sklarm/Library/Arduino15/packages/esp32/hardware/esp32/3.1.2\"/tools/gen_insights_package.py /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA snap-apart-super-debug.ino \"/Users/sklarm/Documents/Arduino/snap-apart-super-debug\""
/usr/bin/env bash -c "[ ! -d \"/Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA\"/libraries/ESP_SR ] || [ ! -f \"/Users/sklarm/Library/Arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-489d7a2b-v1/esp32\"/esp_sr/srmodels.bin ] || cp -f \"/Users/sklarm/Library/Arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-489d7a2b-v1/esp32\"/esp_sr/srmodels.bin \"/Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA\"/srmodels.bin"
/Users/sklarm/Library/Arduino15/packages/esp32/tools/esptool_py/4.9.dev3/esptool --chip esp32 merge_bin -o /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.merged.bin --fill-flash-size 4MB --flash_mode keep --flash_freq keep --flash_size keep 0x1000 /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.bootloader.bin 0x8000 /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.partitions.bin 0xe000 /Users/sklarm/Library/Arduino15/packages/esp32/hardware/esp32/3.1.2/tools/partitions/boot_app0.bin 0x10000 /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.bin
esptool.py v4.8.1
Wrote 0x400000 bytes to file /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.merged.bin, ready to flash to offset 0x0
Using library Adafruit NeoPixel at version 1.12.4 in folder: /Users/sklarm/Documents/Arduino/libraries/Adafruit_NeoPixel
Using library Adafruit Keypad at version 1.3.2 in folder: /Users/sklarm/Documents/Arduino/libraries/Adafruit_Keypad
/Users/sklarm/Library/Arduino15/packages/esp32/tools/esp-x32/2405/bin/xtensa-esp32-elf-size -A /Users/sklarm/Library/Caches/arduino/sketches/6CD542896AADE3D0AA3C14E9EBE13CAA/snap-apart-super-debug.ino.elf
Sketch uses 316556 bytes (24%) of program storage space. Maximum is 1310720 bytes.
Global variables use 21264 bytes (6%) of dynamic memory, leaving 306416 bytes for local variables. Maximum is 327680 bytes.
