Cannot initialize SD Datalogger on Mega2560
Re: Cannot initialize SD Datalogger on Mega2560
You need to use "soft spi" for the Mega. Change:
#define MEGA_SOFT_SPI 0
to:
#define MEGA_SOFT_SPI 1
Vitor
Post by Vitor »
Sorry, it was a typo, MEGA_SOFT_SPI 1 is the correct setting I have in the Sd2Card.h file
Here's the whole sketch.
By the way, I suspect I have a Chinese Arduino Mega card, I have ordered a genuine just in case that is my problem. If this is the case, what would be the difference or the problem?
SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module
created 28 Mar 2011
by Limor Fried
// include the SD library:
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10 *** THIS WORKS FOR ARDUINO UNO ****
// Sparkfun SD shield: pin 8
const int chipSelect = 10;
void setup()
Serial.begin(9600);
Serial.print("\nInitializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(53, OUTPUT); // original is 10, change this to 53 on a ## mega ##
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card is inserted?");
Serial.println("* Is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
return;
else {
Serial.println("Wiring is correct and a card is present.");
// print the type of card
Serial.print("\nCard type: ");
switch(card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
break;
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
break;
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
break;
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
return;
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("\nVolume type is FAT");
Serial.println(volume.fatType(), DEC);
Serial.println();
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
volumesize *= 512; // SD card blocks are always 512 bytes
Serial.print("Volume size (bytes): ");
Serial.println(volumesize);
Serial.print("Volume size (Kbytes): ");
volumesize /= 1024;
Serial.print("Volume size (Mbytes): ");
volumesize /= 1024;
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
Here's Sd2Card.h file
/* Arduino Sd2Card Library
 * Copyright (C) 2009 by William Greiman
 * This file is part of the Arduino Sd2Card Library
 * This Library is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, either version 3 of the License, or
 * (at your option) any later version.
 * This Library is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or BANNED FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with the Arduino Sd2Card Library.  If not, see
 * <http://www.gnu.org/licenses/>.
#ifndef Sd2Card_h
#define Sd2Card_h
 * \file
 * Sd2Card class
#include "Sd2PinMap.h"
#include "SdInfo.h"
/** Set SCK to max rate of F_CPU/2. See Sd2Card::setSckRate(). */
uint8_t const SPI_FULL_SPEED = 0;
/** Set SCK rate to F_CPU/4. See Sd2Card::setSckRate(). */
uint8_t const SPI_HALF_SPEED = 1;
/** Set SCK rate to F_CPU/8. Sd2Card::setSckRate(). */
uint8_t const SPI_QUARTER_SPEED = 2;
 * Define MEGA_SOFT_SPI non-zero to use software SPI on Mega Arduinos.
 * Pins used are SS 10, MOSI 11, MISO 12, and SCK 13.
 * MEGA_SOFT_SPI allows an unmodified Adafruit GPS Shield to be used
 * on Mega Arduinos.  Software SPI works well with GPS Shield V1.1
 * but many SD cards will fail with GPS Shield V1.0.
#if MEGA_SOFT_SPI && (defined(__AVR_ATmega1280__)||defined(__AVR_ATmega2560__))
#define SOFTWARE_SPI
#endif  // MEGA_SOFT_SPI
// SPI pin definitions
#ifndef SOFTWARE_SPI
// hardware pin defs
 * SD Chip Select pin
 * Warning if this pin is redefined the hardware SS will pin will be enabled
 * as an output by init().  An avr processor will not function as an SPI
 * master unless SS is set to output mode.
/** The default chip select pin for the SD card is SS. */
uint8_t const  SD_CHIP_SELECT_PIN = SS_PIN;
// The following three pins must not be redefined for hardware SPI.
/** SPI Master Out Slave In pin */
uint8_t const  SPI_MOSI_PIN = MOSI_PIN;
/** SPI Master In Slave Out pin */
uint8_t const  SPI_MISO_PIN = MISO_PIN;
/** SPI Clock pin */
uint8_t const  SPI_SCK_PIN = SCK_PIN;
/** optimize loops for hardware SPI */
#define OPTIMIZE_HARDWARE_SPI
#else  // SOFTWARE_SPI
// define software SPI pins so Mega can use unmodified GPS Shield
/** SPI chip select pin */
uint8_t const SD_CHIP_SELECT_PIN = 10;
uint8_t const SPI_MOSI_PIN = 11;
uint8_t const SPI_MISO_PIN = 12;
uint8_t const SPI_SCK_PIN = 13;
#endif  // SOFTWARE_SPI
/** Protect block zero from write if nonzero */
#define SD_PROTECT_BLOCK_ZERO 1
/** init timeout ms */
uint16_t const SD_INIT_TIMEOUT = 2000;
/** erase timeout ms */
uint16_t const SD_ERASE_TIMEOUT = 10000;
/** read timeout ms */
uint16_t const SD_READ_TIMEOUT = 300;
/** write time out ms */
uint16_t const SD_WRITE_TIMEOUT = 600;
// SD card errors
/** timeout error for command CMD0 */
uint8_t const SD_CARD_ERROR_CMD0 = 0X1;
/** CMD8 was not accepted - not a valid SD card*/
uint8_t const SD_CARD_ERROR_CMD8 = 0X2;
/** card returned an error response for CMD17 (read block) */
uint8_t const SD_CARD_ERROR_CMD17 = 0X3;
/** card returned an error response for CMD24 (write block) */
uint8_t const SD_CARD_ERROR_CMD24 = 0X4;
/**  WRITE_MULTIPLE_BLOCKS command failed */
uint8_t const SD_CARD_ERROR_CMD25 = 0X05;
/** card returned an error response for CMD58 (read OCR) */
uint8_t const SD_CARD_ERROR_CMD58 = 0X06;
/** SET_WR_BLK_ERASE_COUNT failed */
uint8_t const SD_CARD_ERROR_ACMD23 = 0X07;
/** card's ACMD41 initialization process timeout */
uint8_t const SD_CARD_ERROR_ACMD41 = 0X08;
/** card returned a bad CSR version field */
uint8_t const SD_CARD_ERROR_BAD_CSD = 0X09;
/** erase block group command failed */
uint8_t const SD_CARD_ERROR_ERASE = 0X0A;
/** card not capable of single block erase */
uint8_t const SD_CARD_ERROR_ERASE_SINGLE_BLOCK = 0X0B;
/** Erase sequence timed out */
uint8_t const SD_CARD_ERROR_ERASE_TIMEOUT = 0X0C;
/** card returned an error token instead of read data */
uint8_t const SD_CARD_ERROR_READ = 0X0D;
/** read CID or CSD failed */
uint8_t const SD_CARD_ERROR_READ_REG = 0X0E;
/** timeout while waiting for start of read data */
uint8_t const SD_CARD_ERROR_READ_TIMEOUT = 0X0F;
/** card did not accept STOP_TRAN_TOKEN */
uint8_t const SD_CARD_ERROR_STOP_TRAN = 0X10;
/** card returned an error token as a response to a write operation */
uint8_t const SD_CARD_ERROR_WRITE = 0X11;
/** attempt to write protected block zero */
uint8_t const SD_CARD_ERROR_WRITE_BLOCK_ZERO = 0X12;
/** card did not go ready for a multiple block write */
uint8_t const SD_CARD_ERROR_WRITE_MULTIPLE = 0X13;
/** card returned an error to a CMD13 status check after a write */
uint8_t const SD_CARD_ERROR_WRITE_PROGRAMMING = 0X14;
/** timeout occurred during write programming */
uint8_t const SD_CARD_ERROR_WRITE_TIMEOUT = 0X15;
/** incorrect rate selected */
uint8_t const SD_CARD_ERROR_SCK_RATE = 0X16;
// card types
/** Standard capacity V1 SD card */
uint8_t const SD_CARD_TYPE_SD1 = 1;
/** Standard capacity V2 SD card */
uint8_t const SD_CARD_TYPE_SD2 = 2;
/** High Capacity SD card */
uint8_t const SD_CARD_TYPE_SDHC = 3;
 * \class Sd2Card
 * \brief Raw access to SD and SDHC flash memory cards.
class Sd2Card {
 public:
  /** Construct an instance of Sd2Card. */
  Sd2Card(void) : errorCode_(0), inBlock_(0), partialBlockRead_(0), type_(0) {}
  uint32_t cardSize(void);
  uint8_t erase(uint32_t firstBlock, uint32_t lastBlock);
  uint8_t eraseSingleBlockEnable(void);
   * \return error code for last error. See Sd2Card.h for a list of error codes.
  uint8_t errorCode(void) const {return errorCode_;}
  /** \return error data for last error. */
  uint8_t errorData(void) const {return status_;}
   * Initialize an SD flash memory card with default clock rate and chip
   * select pin.  See sd2Card::init(uint8_t sckRateID, uint8_t chipSelectPin).
  uint8_t init(void) {
    return init(SPI_FULL_SPEED, SD_CHIP_SELECT_PIN);
   * Initialize an SD flash memory card with the selected SPI clock rate
   * and the default SD chip select pin.
   * See sd2Card::init(uint8_t sckRateID, uint8_t chipSelectPin).
  uint8_t init(uint8_t sckRateID) {
    return init(sckRateID, SD_CHIP_SELECT_PIN);
  uint8_t init(uint8_t sckRateID, uint8_t chipSelectPin);
  void partialBlockRead(uint8_t value);
  /** Returns the current value, true or false, for partial block read. */
  uint8_t partialBlockRead(void) const {return partialBlockRead_;}
  uint8_t readBlock(uint32_t block, uint8_t* dst);
  uint8_t readData(uint32_t block,
          uint16_t offset, uint16_t count, uint8_t* dst);
   * Read a cards CID register. The CID contains card identification
   * information such as Manufacturer ID, Product name, Product serial
   * number and Manufacturing date. */
  uint8_t readCID(cid_t* cid) {
    return readRegister(CMD10, cid);
   * Read a cards CSD register. The CSD contains Card-Specific Data that
   * provides information regarding access to the card's contents. */
  uint8_t readCSD(csd_t* csd) {
    return readRegister(CMD9, csd);
  void readEnd(void);
  uint8_t setSckRate(uint8_t sckRateID);
  /** Return the card type: SD V1, SD V2 or SDHC */
  uint8_t type(void) const {return type_;}
  uint8_t writeBlock(uint32_t blockNumber, const uint8_t* src);
  uint8_t writeData(const uint8_t* src);
  uint8_t writeStart(uint32_t blockNumber, uint32_t eraseCount);
  uint8_t writeStop(void);
 private:
  uint32_t block_;
  uint8_t chipSelectPin_;
  uint8_t errorCode_;
  uint8_t inBlock_;
  uint16_t offset_;
  uint8_t partialBlockRead_;
  uint8_t status_;
  uint8_t type_;
  // private functions
  uint8_t cardAcmd(uint8_t cmd, uint32_t arg) {
    cardCommand(CMD55, 0);
    return cardCommand(cmd, arg);
  uint8_t cardCommand(uint8_t cmd, uint32_t arg);
  void error(uint8_t code) {errorCode_ = code;}
  uint8_t readRegister(uint8_t cmd, void* buf);
  uint8_t sendWriteCommand(uint32_t blockNumber, uint32_t eraseCount);
  void chipSelectHigh(void);
  void chipSelectLow(void);
  void type(uint8_t value) {type_ = value;}
  uint8_t waitNotBusy(uint16_t timeoutMillis);
  uint8_t writeData(uint8_t token, const uint8_t* src);
  uint8_t waitStartBlock(void);
#endif  // Sd2Card_h
Post photos of the suspect Mega and let us know how things work with the genuine card. :)
Vitor
Post by Vitor »
I received my new very genuine Arduino Mega 2560. No need to mess with the suspect one.
My excitement was very short lived.
I'm getting exactly the same message.
Initializing SD card...initialization failed. Things to check:
Went back to the UNO to make sure the datalogger card is still good.
Still works.
Vitor
Post by Vitor »
Update.
As suggested in another thread.
You must do a complete wipe of the IDE and the old Arduino document folder. REALLY!!
I spent one month messing with 3 Arduino Megas.
Completely delete the IDE
Remove the Arduino folder from My Documents, save it at a separate location, a new one will be created when you first use the new clean install of the IDE.
For IDE 22 and 23 delete the SD library from the Libraries folder and install the one from Adafruit.
Change the setting for the soft SPI
It will work!!!
For IDE 1.0 I left the existing SD library, I was impressed with the speed using the UNO, the 1280 and 2560 Megas.
I will try with Adafruit library later and see what I get.
Anyway, thank you all.
dr. nefario
Post by dr. nefario »
Just a dumb question. Since I have the shield build and working with the 1.0 IDE library, where can I go to look for some in depth look at how the libraries work for writing to the SD card? Also I would like to signal the diodes to signify the read / write cycle. Are there any info on getting those to work? Thanks in advance!
I'm going to try to implement the high speed serial port library on my 2560. I uploaded the code, but I was not able to get it working as of yet.
The best way to get to know what the libraries do is to read through the source code.
There are breakout pads for the leds near the digital pin header. If you jumper the leds to digital pins as in the "fridgeLogger" project, you can use them to indicate anything you want.
For those coming across this topic late, it is somewhat out of date. The current version of the Adafruit SD library has software SPI built-in:
https://learn.adafruit.com/adafruit-dat ... d-leonardo
