MarOS1.5.0 - Beta Version
by mario1089 on Fri Oct 26, 2012 1:35 pm
MarOS 1.5.0
UPDATED FOR VERSION 1.5.0
Here is my new alternative firmware for the x0xb0x called MarOS1.5.0 It`s based on sokkOS2.0 and adds quite a bunch of fresh features.
This latest version contains various improvements on features, workflows, fixes bugs etc. Storing and Restoring Runtime Paramter Presets may be the most obvious improvement, but please read the new documentation to get an overview. (06/05/2016)
User nordcore has rewritten significant parts of the code, and thereby freed a lot of memory space. He also improved the timing and stability of the machine. Nevertheless, as of now, DIN Sync, and MIDI Beat Clock Output, as much as several other features, are sort of untested. I'll be here for a while to fix severe bugs, if I can. After the biggest problems are fixed (if any), I'll post the source code, let others continue to work on this.
So this version is a "beta".
Features:
-- MIDI Sync Mode significantly changed: Start/Stop, trigger patterns, transposing patterns including automatic scale correction – all by MIDI notes from your DAW / Midi keyboard.
-- Smart randomizer and macro functions to create cool patterns without any step editing. 20(!) macro / randomizer commands available in edit mode.
-- New Swing: Now allowing for fine adjustable swing 0%...100%.
-- Swing applied to both MIDI clock and Din Sync output.
-- Adjustable Gate Length allowing for shorter notes or almost gapless patterns.
-- Automatic Random Variations of current pattern to have the xox be kinda "jamming" - adjustable for accents, slides, octaves, rests and where and how often variations should happen.
-- Parameter Adjustment Mode - all new sequencer parameters editable with the tempo knob and visible on the bank LED.
Hex-file and documentation you find here:
MarOS15.zip
- Source Code
- (64.37 KiB) Downloaded 462 times
MarOS1.5 Documentation.zip
- Doc
- (209.66 KiB) Downloaded 1002 times
MarOS150.zip
- The Hex.
- (17 KiB) Downloaded 648 times
mario1089 on Tue Nov 22, 2016 9:46 pm, edited 14 times in total.
