NEOPIXEL brightness control
Re: NEOPIXEL brightness control
It may start to get a little tight for space with 86 pixels on a trinket. It depends on how complex your code gets.
- Rated_M
Okay, I spent several hours trying to understand and manipulate the code in the Multitasking Part 3 tutorial, but alas much of it appears to be beyond my comprehension, and also far more complex than needed for what I am trying to accomplish.
I don't need to control multiple neopixel segments independently and simultaneously, just one. (My 86 neopixels is actually only 2 strips of 43 doing the same function for front/back display)
I only need black(0,0,0) plus orange(255,128,0), and the brightness/color levels in between for fade up/down.
The IDLE pattern just does fade up/down, the breathing sketch is perfect for this.
The Button1 press CHARGE pattern needs to do fade up, then fast flash continuously until Button2 press.
The Button2 press FIRE pattern is just one flash of max brightness followed by an ascending fast scanner/cylon then back to IDLE.
I understand the premise of getting the patterns outside the loop and just using the loop to check status of the inputs, so it sounds like I will need to do something like that to get the results I want, but is there a simpler way? If not can you or anyone cite some other less complex example sketches available that I could try to model after?
Any guidance appreciated.
Thanks again.
Thanks again.
Start simple. Take it one step at a time.
If you only have one set of pixels, only define one.
Get the fade working first. That is trivial.
Next, implement button 1.
When that is working, implement button 2.
NeoPatterns Pixels(43, 5, NEO_GRB + NEO_KHZ800, &PixelsComplete);
// Initialize all the pixelStrips
Pixels.begin();
// Kick off a pattern
Pixels.Fade(Pixels.Color(0,0,0), Pixels.Color(255,128,0), 100, 1); // black to orange
- Tissi_2
I want to get back to the "breathing code" that was posted earlier and is still related to the main topic of this thread ( I hope so ). If I load this code up to the arduino, the arduino does not respond to any other inputs from a button or a rotary encoder. Why is it like this and how do I get out of that loop? I tried it with a for loop:
Are you working on an implementation of "new features" like brightness control for each pixel into you neopixel.h?
for(int rep = 0; rep <5; rep++){ "breathing code"}
If you want your code to remain responsive to inputs while updating the pixel patterns, you need a completely different approach.If I load this code up to the arduino, the arduino does not respond to any other inputs from a button or a rotary encoder. Why is it like this and how do I get out of that loop?
See this guide for details: https://learn.adafruit.com/multi-taskin ... 3/overview
- sergneri
Anyone figure out how to use breathe and change color? That sine loop is endless, which is great, if one could just change colors at the bottom of the loop or every 5 iterations.
Merci Bien!
Merci Bien!
- adafruit_support_rick
You mean this breathe function?
What about doing this?
#define TOTAL_LEDS 60
void loop()
breathe(255, 0.008, 5);
void breathe(float MaximumBrightness, float SpeedFactor, float StepDelay)
// Make the lights breathe
for (int i = 0; i < 65535; i++) {
// Intensity will go from 10 - MaximumBrightness in a "breathing" manner
float intensity = MaximumBrightness /2.0 * (1.0 + sin(SpeedFactor * i));
strip.setBrightness(intensity);
// Now set every LED to that color
for (int ledNumber=0; ledNumber<TOTAL_LEDS; ledNumber++) {
strip.setPixelColor(ledNumber, 0, 0, 255);
strip.show();
//Wait a bit before continuing to breathe
delay(StepDelay);
void loop()
breathe(strip.Color(255, 0, 0), 255, 0.008, 5);
breathe(strip.Color(0, 255, 0), 255, 0.008, 5);
breathe(strip.Color(0, 0, 255), 255, 0.008, 5);
void breathe(uint32_t color, float MaximumBrightness, float SpeedFactor, float StepDelay)
strip.setPixelColor(ledNumber, color);
strip.show();
delay(StepDelay);
- sergneri
Yes, that is the one, thank you.
In my many failed attempts to do this, I didn't use the strip.Color(255, 0, 0) argument, rather, just tried to set variables to color values and passed them along, which didn't work. I did type them correctly, normally using the uint32_t type.
Also, I see that the value for the i loop can be reduced from 65535 for quicker runs. I'm using 5530 at the moment. With the quicker loop time,
Great thread, thanks everyone.
- chargerdude70
With code attached, I expect it to run 5 times and then move onto another sequence but it doesn't. Could someone explain why and suggest a correction?
// Breathing effect
int breathIng = 0;
for (breathIng; breathIng < 5; breathIng ++) {
float intensity = MaximumBrightness / 2.0 * (1.0 + sin(SpeedFactor * i));
pixels.setBrightness(intensity);
for (int ledNumber = 0; ledNumber < NUMPIXELS; ledNumber++) {
pixels.setPixelColor(ledNumber, REDo);
pixels.show();
delay(StepDelay);
- sergneri
I believe the number of loops is set here for (int i = 0; i < 65535; i++)
I am playing with values in the 2200 range and seeing 3 to 4 loops, 5800 gave me around 8.
Trick for me is to now get a color change during the minimum intensity value - so one can play with SpeedFactor as well but I'm essentially guessing when the minimum will occur. This code is not right, color change can happen on ramp up or down but is not synced.
#ifdef __AVR_ATtiny85__ // Trinket, Gemma, etc.
#include <avr/power.h>
#endif
#define PIN 1
Adafruit_NeoPixel strip = Adafruit_NeoPixel(40, PIN);
uint32_t color = (0,0,0); // Start dark
#define TOTAL_LEDS 40
// put your setup code here, to run once:
if(F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
strip.begin();
strip.setBrightness(0); // 1/3 brightness
strip.show();
// 0.08 speedfactor is fast blinking
// 0.018 is medium fast
uint8_t r = random(0x22, 0xff);
uint8_t g = random(0x22, 0xff);
uint8_t b = random(0x22, 0xff);
breathe(strip.Color(r, g, b), 50, 0.008, 5);
// breathe(strip.Color(0, 255, 0), 105, 0.010, 5);
// breathe(strip.Color(0, 0, 255), 105, 0.010, 5);
float intensity;
// 5530 = 8 iterations
for (int i = 0; i < 2200; i++) {
strip.show();
delay(StepDelay);
You guys might want to have a look at the breathing sketch I wrote a while ago.
BreatheRightStrip.ino:
#include "Adafruit_NeoPixel.h"
#include "SPI.h"
//Demonstrates "breathing" effect on NeoPixel Strip
#define LED_PIN 6
#define N_LEDS 16
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
uint8_t LED_Breathe_Table[] = { 80, 87, 95, 103, 112, 121, 131, 141, 151, 161, 172, 182, 192, 202, 211, 220,
228, 236, 242, 247, 251, 254, 255, 255, 254, 251, 247, 242, 236, 228, 220, 211,
202, 192, 182, 172, 161, 151, 141, 131, 121, 112, 103, 95, 87, 80, 73, 66,
60, 55, 50, 45, 41, 38, 34, 31, 28, 26, 24, 22, 20, 20, 20, 20,
20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20,
20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 22, 24, 26, 28,
31, 34, 38, 41, 45, 50, 55, 60, 66, 73 };
#define BREATHE_TABLE_SIZE (sizeof(LED_Breathe_Table))
#define BREATHE_CYCLE 6000 /*breathe cycle in milliseconds*/
#define BREATHE_UPDATE (BREATHE_CYCLE / BREATHE_TABLE_SIZE)
// Start up the LED strip
strip.begin();
// Update the strip, to start they are all 'off'
strip.show();
int cycle;
for (cycle=0; cycle < 4; cycle++) {
uniformBreathe(LED_Breathe_Table, BREATHE_TABLE_SIZE, BREATHE_UPDATE, 256, 256, 256);
sequencedBreathe(LED_Breathe_Table, BREATHE_TABLE_SIZE, BREATHE_UPDATE, 256, 256, 256);
void uniformBreathe(uint8_t* breatheTable, uint8_t breatheTableSize, uint16_t updatePeriod, uint16_t r, uint16_t g, uint16_t b)
int i;
uint8_t breatheIndex = 0;
uint8_t breatheRed;
uint8_t breatheGrn;
uint8_t breatheBlu;
for (breatheIndex = 0; breatheIndex < breatheTableSize; breatheIndex++) {
for (i=0; i < strip.numPixels(); i++) {
breatheRed = (r * breatheTable[breatheIndex]) / 256;
breatheGrn = (g * breatheTable[breatheIndex]) / 256;
breatheBlu = (b * breatheTable[breatheIndex]) / 256;
strip.setPixelColor(i, breatheRed, breatheGrn, breatheBlu);
strip.show(); // write all the pixels out
delay(updatePeriod);
void sequencedBreathe(uint8_t* breatheTable, uint8_t breatheTableSize, uint16_t updatePeriod, uint16_t r, uint16_t g, uint16_t b)
int i;
uint8_t breatheRed;
uint8_t breatheGrn;
uint8_t breatheBlu;
uint8_t sequenceIndex;
sequenceIndex = (breatheIndex + (i*4)) % breatheTableSize;
breatheRed = (r * breatheTable[sequenceIndex]) / 256;
breatheGrn = (g * breatheTable[sequenceIndex]) / 256;
breatheBlu = (b * breatheTable[sequenceIndex]) / 256;
- chargerdude70
@ adafruit_support_rick
I tried to compile your "BreatheRightStrip" code and receive this error in Arduino 1.0.5
"no matching function for call to Adafruit_NeoPixel::Adafruit_NeoPixel(int,int,int)"
and this error in 1.6.5
Arduino-V1.6.5-r2\libraries\SPI/SPI.h:67:16: error: 'SPIE' was not declared in this scope
SPCR &= ~_BV(SPIE);
Can you assist?
SPCR &= ~_BV(SPIE);
Can you assist?
It compiles for me in 1.6.5 with Uno as the target. What's your target processor?
- chargerdude70
ATtiny85,is there something I can change for it to work?
And just verified that it does compile on 1.6.5 with UNO as target
Delete the line #include "SPI.h"
I don't know how that got in there in the first place...
