NEOPIXEL brightness control
chargerdude70
Re: NEOPIXEL brightness control
Post by chargerdude70 »
Thank you Rick for your support and responses to this thread. For the life of me I can not get my code to function as intended so I went as simple with it as possible and still can't. I have added what I thought were the necessary items to the library that were posted on the fist page of this thread. My intentions are to have a theater chase with a variable fade as well as color choice. But I can not get a simple "on/off" to work while being variable. Could you please assist?
THIS CODE DOES NOT WORK
//Mandatory items to make NEOPIXELS function
const int ledNum = 9; // Number of LED's
const int ledPin = 0; // ATtiny85 LED signal output pin #
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(ledNum, ledPin);
//add ons
uint32_t Blue = pixels.Color(0, 0, 255);
  pixels.begin();
  pixels.show();
  pinMode(ledPin, OUTPUT);
// Set each pixel brightness individually
void setPixelColor( uint16_t n, uint8_t r, uint8_t g, uint8_t b, uint16_t brightness) {
   pixels.setPixelColor(n, (brightness*r/255) , (brightness*g/255), (brightness*b/255));
void setPixelColor (uint16_t n, uint32_t c, uint16_t brightness);
void loop()
   pixels.setPixelColor(1, Blue, 250);
   pixels.show();
   delay(1000);
   pixels.setPixelColor(1, Blue, 125);
   pixels.show();
   delay(1000);
THIS CODE WORKS
//add ons
  pixels.begin();
  pixels.show();
// Set each pixel brightness individually using uint32_t
void setPixelColor (uint16_t n, uint32_t c, uint16_t brightness){
void loop()
   pixels.setPixelColor(1, 0,0,255, 250);
   pixels.show();
   delay(1000);
   pixels.setPixelColor(1, 0,0,255, 125);
   pixels.show();
   delay(1000);
adafruit_support_rick
Post by adafruit_support_rick »
You must have added a new setPixelColor function to the library? Otherwise, your second set of code would not compile. You don't need the setPixelColor functions that you have in the sketch - you aren't calling those.
chargerdude70
I added this to .ccp
// Set pixel brightness individually using seperate R,G,B components:
void Adafruit_NeoPixel::setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b, uint16_t brightness) {
// Set pixel brightness individually using a 'packed' 32-bit RGB color:
void Adafruit_NeoPixel::setPixelColor(uint16_t n, uint32_t c, uint16_t brightness) {
and this to .h
setPixelColor(uint16_t n, uint32_t c, uint16_t brightness),
Doing that
This code works as expected
//uint32_t Blue = pixels.Color(0, 0, 255);
  pixels.begin();
  pixels.show();
void loop()
   pixels.show();
   delay(1000);
   pixels.show();
   delay(1000);
This code compiles, but the pixel does light at all. Is there something wrong with the code I added to the .ccp and .h files?
  pixels.begin();
  pixels.show();
void loop()
   pixels.show();
   delay(1000);
   pixels.show();
   delay(1000);
Yes - the function that takes three arguments is empty:
It doesn't do anything. What you want to do is break out the three colors, and then call the other setPixelColor:
   uint8_t
      r = (uint8_t)(c >> 16),
      g = (uint8_t)(c >>  8),
      b = (uint8_t)c;
  setPixelColor(n, r, g, b, brightness);
chargerdude70
Thank you very much Rick. I thought that line of code was missing something. But with me not knowing anything about programming, I wasn't sure. With code given by you, my test code works as expected. Again, thank you for your assistance and support on the forum.
You're welcome!
chargerdude70
Rick, this code (chasefade) is why all the questions about fading lights with a separate variable. I wrote this code similar to another I use (using a "for" statement) as a "breathing" effect but the lights remain at the initial setting and won't increment.
lights dont fade
//chaseFade....Make lights fade from low to high intensity while lighting one after another
uint16_t i, l;
#define DELAY 30 // Time delay between Pixels
  pixels.begin();
  pixels.show();
// chaseFade
  int chase = 0;
  for (chase; chase < 5; chase++) {
    for (l = 28; l < 255; l = l+28) {
      for (i = 0; i < ledNum; i++) {
        pixels.setPixelColor(i, Blue, l);
        pixels.show();
        delay(DELAY);
        pixels.setPixelColor(i, 0, 0, 0);
        pixels.show();
      delay(1000);
lights do fade
 // Breathing effect
    for(breathIng; breathIng < 5; breathIng ++){
      for(j = 0; j < 254; j=j+2) {
        for(i=0; i<pixels.numPixels(); i++) {
          pixels.setPixelColor(i, pixels.Color(0,j,0));
          pixels.show();
      for(j = 254; j > 0; j=j-2) {
          pixels.show();
      for(i=0; i<15; i++) {
        pixels.setPixelColor(i, 0,0,0);
        pixels.show();
    delay(500);
I don't know. That should work. Your code looks OK. Does the new brightness function actually work? Have you tested it?
chargerdude70
Yes...if I set up a simple on/off code for one or multiple leds...it will set a variable set color to a variable set brightness...just not in a "for" statement
chargerdude70
Sorry Rick..I was wrong....the code does work. What it does is light the LEDs in sequence at a common intensity and increments the intensity the specified value with each new pass until full intensity has been achieved. What I am trying to do is get the LEDs to light in sequence while having them go up in intensity until full brightness in the same pass. Then repeat. I have tried to rearrange the code to best of my abilities but can not achieve my desired effect. Is this something possible? If so, can you assist?
So I understand you just want one LED lit at any given time? You want to sequence through the LEDs one at a time, each time increasing the brightness?
Or do you want each LED to stay lit, and just get brighter on each pass?
chargerdude70
Rick..the best to describe is the 16 led neopixle ring...starting at 0 and sequencing to 15...I would like the lights to light one at a time..the first being the dimist staying on till the last being the brightest...then repeat as desired...a chase with an incremental reverse fade so to speak...
Does this do what you want?
uint16_t i, l;
  pixels.begin();
  pixels.show();
// chaseFade
  int chase = 0;
  uint8_t brightIncrement = 255 / pixels.numPixels();
      pixels.setPixelColor(i, Blue, ((i + 1) * brightIncrement));
      pixels.show();
      delay(DELAY);
      pixels.show();
    delay(1000);
chargerdude70
Yes sir Rick..Exactly...I wrote something kind of on the lines of yours but could not get it to work. Thank you for all your assistance.
You're welcome!
