NEOPIXEL brightness control
Tissi_2
Re: NEOPIXEL brightness control
Post by Tissi_2 »
I have 3 neopixel rings 16. I am trying to combine the color wheel function with the breathing effect, but I don´t get it working. I dont know how to implement the brightness table code.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
   WheelPos -= 170;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
void rainbowCycleRing1(uint8_t wait) {
    for(i=0; i<16; i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / 16) + j) & 255));
    for(i=16; i<48; i++) {
      strip.setPixelColor(i, strip.Color(0,0,0));
    strip.show();
Does the table need a specific number of values? As I modified the table values by adding, erasing or editing values, the pixels kind of moved clockwise. Is there a chance of changing the brightness of all pixels and also being able to receive button inputs (multitasking)?
BulldogLowell
Post by BulldogLowell »
adafruit_support_rick wrote:You're welcome!
"Breathing" new life to this thread...
I'm looking for a prototype class for "breathing" a subset of a neopixel array.
i.e fix the color of pixel 0 through 9 and breathe pixels 10-15.
my thinking is to create an array of elements to breathe:
const uint8_t breathyBit[8] = {10,11,12,13,14,15};
and address that array from a function:
void breathSegment(const uint8_t * segment)
    fadeSegment( )
leaving the state of the other pixels unchanged.
BulldogLowell
OK, so I figured out a quick way...
void breatheUpdate(const uint8_t * segment, const uint32_t increment, const uint8_t step)
  static uint32_t lastTimeChange = 0;
  static uint8_t direction = 1;
  static uint8_t value;
  if(millis() - lastTimeChange > increment)
    value += (direction * step);
    if (value <=0 || value >= 255)
      direction = direction * -1;
    for(uint8_t i = 0; i < sizeof(segment) * 2; i++)
      myPixels.setPixelColor(segment[i], myPixels.Color(0, 0, value));
    myPixels.show();
    lastTimeChange += increment;
and put this in your loop() function
void loop()
  breatheUpdate(currentWeather, BREATH_RATE, 1);
mjemlemm
Post by mjemlemm »
I want to fade my neopixel and I used this code:
#define TOTAL_LEDS 60
void loop()
  breathe(strip.Color(255, 0, 0), 255, 0.008, 5);
  breathe(strip.Color(0, 255, 0), 255, 0.008, 5);
  breathe(strip.Color(0, 0, 255), 255, 0.008, 5);
void breathe(uint32_t color, float MaximumBrightness, float SpeedFactor, float StepDelay)
  // Make the lights breathe
  for (int i = 0; i < 65535; i++) {
    // Intensity will go from 10 - MaximumBrightness in a "breathing" manner
    float intensity = MaximumBrightness /2.0 * (1.0 + sin(SpeedFactor * i));
    strip.setBrightness(intensity);
    // Now set every LED to that color
    for (int ledNumber=0; ledNumber<TOTAL_LEDS; ledNumber++) {
      strip.setPixelColor(ledNumber, color);
    strip.show();
    //Wait a bit before continuing to breathe
    delay(StepDelay);
it worked! but I don't know what to change to go from low brightness to high brightness in stead off from high to low, that's what he is doing at the moment.
Can someone help me? I am very new at this
Last edited by adafruit_support_bill on Tue Oct 06, 2015 2:38 pm, edited 1 time in total.
Reason: Please use [code] tags when submitting code to the forums
change this line:
To:
    strip.setBrightness(255-intensity);
rbbtebo
Post by rbbtebo »
What is the difference between:
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(60, PIN); and
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN);
BulldogLowell
rbbtebo wrote:What is the difference between:
in the first, you are naming your instance of an Adafruit_NeoPixel object "pixels" and in the second you are naming it "strip"
so, further down the road, you will access member functions and variables using the pixels or strip name like this"
pixels.show();
or
strip.show();
rbbtebo
Post by rbbtebo »
Confirming then....
It could be ANY name - Dog, cat, mouse, etc. as long as I followed the that convention in the rest of the program....
jimblue
Post by jimblue »
rbbtebo wrote:Confirming then....
Yes. The program looks for name matches. If you use 'dog' in the program, but never defined it, you will get an error.
rbbtebo
Post by rbbtebo »
Adafruit is ALWAYS AWESOME with their help. Thank you!
kit_ho
Post by kit_ho »
Hey guys,
in regards with the breathing code posted at the beginning of this thread, I tried to make a Rainbow breathing strip. Is there a way to change the minimum brightness to 40 or other value instead of fading to 0? I don't know anything about coding.. so, thank you in advance if anyone is able to help.
#define PIN 12
Adafruit_NeoPixel strip = Adafruit_NeoPixel(30, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.show();
  float MaxBrightness = 255;
  float SpeedFactor = 0.008;
  float wait = 25;
  for(int b=0;b<65535;b++) {
    float intensity = MaxBrightness/2.0*(1.0+sin(SpeedFactor*b));
    for (uint8_t i=0;i<strip.numPixels();i++){
      strip.setPixelColor(i,Wheel(i*256/strip.numPixels()));
    strip.show();
    delay(wait);
//Neopixel Wheel - Rainbow
  if (WheelPos < 85) {
  } else if (WheelPos < 170) {
    WheelPos -= 85;
  } else {
    WheelPos -= 170;
Change your loop to something like this:
void loop()
  float MinBrightness = 40;
  float MaxBrightness = 255 - MinBrightness;
  float wait = 25;
    float intensity = MaxBrightness/2.0*(1.0+sin(SpeedFactor*b)) + MinBrightness;
    strip.show();
    delay(wait);
kit_ho
Post by kit_ho »
Thanks a lot! that did the job. :)
kit_ho
Post by kit_ho »
I've sketched a breathing code. Take a look (:
Strip can fade in and out or stay lit for awhile before fading and you can set how many loops for each color. Plus it doesn't use complex calculation that I don't understand xD
Most of the code were found on the net and put together with some tweaks here and there.
Let me know what you guys think, this is my very first project. Does everything looks good and can it be refined and made simpler?
#define PIN 12
#define NUMPIXEL 30   //how many pixel on the strip.
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXEL, PIN, NEO_GRB + NEO_KHZ800);
int MinBrightness = 30;       //value 0-255
int MaxBrightness = 170;      //value 0-255--equation (maxBrightness*maxBrightness/255) hence maxBrightness^2/255 hence the value 170 actually equal to 113.33333 .
int numLoops1 = 4;
int numLoops2 = 2;
int numLoops3 = 5;
int numLoops4 = 3;            //add new integer and value for different colors if needed.
int fadeHoldWait = 300;       //how many steps to stay lit before dimming again.
int fadeInWait = 15;          //lighting up speed, steps.
int fadeOutWait = 30;         //dimming speed, steps.
  strip.begin();
  strip.show();
  //---strip will stay lit for some time before dimming again.----
  rgbFadeIn_Hold_Out(strip.Color(255,0,0),numLoops1);  //red.
  rainbowFadeIn_Hold_Out(numLoops2);
  //---normal breathing.----
  rgbFadeInOut(strip.Color(60,255,0),numLoops3);      //green.
  rainbowFadeInOut(numLoops4);
void rgbFadeIn_Hold_Out(uint32_t c, uint8_t x) {
  for (int j=0;j<x;j++){
    for(uint8_t b=MinBrightness;b<MaxBrightness;b++){
      strip.setBrightness(b*MaxBrightness/255);
      for (uint16_t i=0;i<strip.numPixels();i++){
        strip.setPixelColor(i,c);
      strip.show();
      delay(fadeInWait);
    strip.setBrightness(MaxBrightness*MaxBrightness/255);
      strip.show();
      delay(fadeHoldWait);
    for(uint8_t b=MaxBrightness;b>MinBrightness;b--){
      strip.show();
      delay(fadeOutWait);
void rainbowFadeIn_Hold_Out(uint8_t x) {
      strip.show();
      delay(fadeInWait);
    for(uint8_t i=0;i<strip.numPixels();i++){
      strip.show();
    for (uint8_t b=MaxBrightness;b>MinBrightness;b--){
      for(uint8_t i=0;i<strip.numPixels();i++) {
      strip.show();
      delay(fadeOutWait);
void rgbFadeInOut(uint32_t c, uint8_t x){
  for(int j=0;j<x;j++){
      for(uint16_t i=0;i<strip.numPixels();i++){
      strip.show();
      delay(fadeInWait);
    for(uint8_t b=MaxBrightness;b>MinBrightness;b--) {
      for (uint16_t i=0;i<strip.numPixels();i++) {
      strip.show();
      delay(fadeOutWait);
void rainbowFadeInOut(uint8_t x){
      strip.show();
      delay(fadeInWait);
      for (uint8_t i=0;i<strip.numPixels();i++) {
      strip.show();
      delay(fadeOutWait);
//NeoPixel Wheel for Rainbow-----------------
  WheelPos = 127 - WheelPos;       //the value here means - for 255 the strip will starts with red, 127-red will be in the middle, 0 - strip ends with red.
  if(WheelPos < 85) {
    WheelPos -= 85;
  WheelPos -= 170;
Looks good. You could simplify by combining the FadeInOut functions and the FadeIn_Hold_Out functions by just passing in the "fadeHoldWait" parameter. If you pass in a zero, there is no hold time.
