NEOPIXEL brightness control
- kit_ho
Re: NEOPIXEL brightness control
*poowfftt* mind blown, why didn't I thought about that! Something as simple as that, is very enlightening, thanks again! XD
- UnknownBoyPT
Hello Guys,
I'm also very new at this subject like arduino and leds but I have to do a work for my master degree so I really have to figure something out.
I've this code, and I'd like to make it "breathe" in another color but I couldn't figure it out. Right now it just breathes in white. What should I change?
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 6
#define LEDS 24
const int CYCLE_MILLISECONDS = 5000; // 5 second breathing cycle.
const uint8_t KEYFRAMES[] = {
// Rising
20, 21, 22, 24, 26, 28, 31, 34, 38, 41, 45, 50, 55, 60, 66, 73, 80, 87, 95,
103, 112, 121, 131, 141, 151, 161, 172, 182, 192, 202, 211, 220, 228, 236,
242, 247, 251, 254, 255,
// Falling
254, 251, 247, 242, 236, 228, 220, 211, 202, 192, 182, 172, 161, 151, 141,
131, 121, 112, 103, 95, 87, 80, 73, 66, 60, 55, 50, 45, 41, 38, 34, 31, 28,
26, 24, 22, 21, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20,
unsigned long lastBreath = 0;
int keyframePointer = 0;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(LEDS, PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
strip.show();
int numKeyframes = sizeof(KEYFRAMES) - 1;
float period = CYCLE_MILLISECONDS / numKeyframes;
unsigned long now = millis();
if ((now - lastBreath) > period) {
lastBreath = now;
for (int i = 0; i < strip.numPixels(); i++) {
uint8_t color = (127 * KEYFRAMES[keyframePointer]) / 256;
strip.setPixelColor(i, strip.Color(KEYFRAMES[keyframePointer], KEYFRAMES[keyframePointer], KEYFRAMES[keyframePointer]));
strip.show();
// Increment the keyframe pointer.
if (++keyframePointer > numKeyframes) {
// Reset to 0 after the last keyframe.
Last edited by adafruit_support_bill on Fri Jun 24, 2016 1:11 pm, edited 1 time in total.
Reason: Please use [code] tags when submitting code to the forums
This line sets the R, G and B component of the color to all the same value, so it is white.I'd like to make it "breathe" in another color but I couldn't figure it out. Right now it just breathes in white. What should I change?
- UnknownBoyPT
Could you please explain me how could I do that? Because I already changed that line to something similar to this:adafruit_support_bill wrote:This line sets the R, G and B component of the color to all the same value, so it is white.I'd like to make it "breathe" in another color but I couldn't figure it out. Right now it just breathes in white. What should I change?If you want a different color, first you need to define what the RGB components of that color are, then scale the values proportionally for the fade.Code: Select all
strip.setPixelColor(i, 255, 0, 0);
But then the lights just stay in fixed red color and not breathing anymore
strip.setPixelColor(i, KEYFRAMES[keyframePointer], 0, 0);
- UnknownBoyPT
Thank you very much! And what should I do to change it to other colors? Like Yellow, Pink, or other colors with RGB color code? Because I was trying with some of them but it didn't work.adafruit_support_bill wrote:Code: Select all
The general formula is:
strip.setPixelColor(i, (Red * KEYFRAMES[keyframePointer]) / 255, (Green* KEYFRAMES[keyframePointer]) / 255, (Blue* KEYFRAMES[keyframePointer]) / 255);
- UnknownBoyPT
Thank you so much! It worked perfectly!adafruit_support_bill wrote:The general formula is:
One last question, is it possible to make it "breathe" with different breathing? In another words, as we human, we always breathe differently, one more intense or less, and so on. Is is possible to do the same here? To make it look more "natural" instead of just fade in and fade out?
One thing that would be fairly straightforward to do is to randomize the timing a bit. Changing CYCLE_MILLISECONDS will alter the rhythm of the breathing. The random function is documented here: https://www.arduino.cc/en/Reference/Random
- UnknownBoyPT
Thank you! I'll check on that!adafruit_support_bill wrote:One thing that would be fairly straightforward to do is to randomize the timing a bit. Changing CYCLE_MILLISECONDS will alter the rhythm of the breathing. The random function is documented here: https://www.arduino.cc/en/Reference/Random
- kenan03
this is my first project and it will include a strip segment of neopixel strip as well as two nexopixel rings (the 16 pixel version). I was wanting to make the entire set of lights have a light blue color breathing effect. I was directed to @adafruit_support_rick who provided a very helpful code for a breathing light pattern (quoted below). How would I need to modify this code to make it work with the setup I have above (one strip and two rings all connected). Thank you in advance!
Albert
Albert
adafruit_support_rick wrote:You guys might want to have a look at the breathing sketch I wrote a while ago.
BreatheRightStrip.ino:
#include "Adafruit_NeoPixel.h" #include "SPI.h" //Demonstrates "breathing" effect on NeoPixel Strip #define LED_PIN 6 #define N_LEDS 16 Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800); uint8_t LED_Breathe_Table[] = { 80, 87, 95, 103, 112, 121, 131, 141, 151, 161, 172, 182, 192, 202, 211, 220, 228, 236, 242, 247, 251, 254, 255, 255, 254, 251, 247, 242, 236, 228, 220, 211, 202, 192, 182, 172, 161, 151, 141, 131, 121, 112, 103, 95, 87, 80, 73, 66, 60, 55, 50, 45, 41, 38, 34, 31, 28, 26, 24, 22, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 22, 24, 26, 28, 31, 34, 38, 41, 45, 50, 55, 60, 66, 73 }; #define BREATHE_TABLE_SIZE (sizeof(LED_Breathe_Table)) #define BREATHE_CYCLE 6000 /*breathe cycle in milliseconds*/ #define BREATHE_UPDATE (BREATHE_CYCLE / BREATHE_TABLE_SIZE) void setup() { // Start up the LED strip strip.begin(); // Update the strip, to start they are all 'off' strip.show(); } void loop() { int cycle; for (cycle=0; cycle < 4; cycle++) { uniformBreathe(LED_Breathe_Table, BREATHE_TABLE_SIZE, BREATHE_UPDATE, 256, 256, 256); } for (cycle=0; cycle < 4; cycle++) { sequencedBreathe(LED_Breathe_Table, BREATHE_TABLE_SIZE, BREATHE_UPDATE, 256, 256, 256); } } void uniformBreathe(uint8_t* breatheTable, uint8_t breatheTableSize, uint16_t updatePeriod, uint16_t r, uint16_t g, uint16_t b) { int i; uint8_t breatheIndex = 0; uint8_t breatheRed; uint8_t breatheGrn; uint8_t breatheBlu; for (breatheIndex = 0; breatheIndex < breatheTableSize; breatheIndex++) { for (i=0; i < strip.numPixels(); i++) { breatheRed = (r * breatheTable[breatheIndex]) / 256; breatheGrn = (g * breatheTable[breatheIndex]) / 256; breatheBlu = (b * breatheTable[breatheIndex]) / 256; strip.setPixelColor(i, breatheRed, breatheGrn, breatheBlu); } strip.show(); // write all the pixels out delay(updatePeriod); } } void sequencedBreathe(uint8_t* breatheTable, uint8_t breatheTableSize, uint16_t updatePeriod, uint16_t r, uint16_t g, uint16_t b) { int i; uint8_t breatheIndex = 0; uint8_t breatheRed; uint8_t breatheGrn; uint8_t breatheBlu; uint8_t sequenceIndex; for (breatheIndex = 0; breatheIndex < breatheTableSize; breatheIndex++) { for (i=0; i < strip.numPixels(); i++) { sequenceIndex = (breatheIndex + (i*4)) % breatheTableSize; breatheRed = (r * breatheTable[sequenceIndex]) / 256; breatheGrn = (g * breatheTable[sequenceIndex]) / 256; breatheBlu = (b * breatheTable[sequenceIndex]) / 256; strip.setPixelColor(i, breatheRed, breatheGrn, breatheBlu); } strip.show(); // write all the pixels out delay(updatePeriod); } }
The only thing you need to change is this line:
Change N_LEDS to the total number of pixels in your strip plus the rings.
#define N_LEDS 16
- Bazeman
I have been trying to get a effect with the neopixels but I won't get it right... At page 4 adafruit_support_rick responded to Chargerdude70 who had added some code to the library individually control each pixel in brightness.. I have tried to add this code also to the library but then afterwards the sketch won't compile anymore.. Can someone exactly tell what lines I have to add were to make this sketch to work:
I hope you guys can help
//chaseFade....Make lights fade from low to high intensity while lighting one after another
const int ledNum = 13; // Number of LED's
const int ledPin = 6; // ATtiny85 LED signal output pin #
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(ledNum, ledPin);
uint32_t Blue = pixels.Color(0, 255, 0);
uint16_t i, l;
#define DELAY 30 // Time delay between Pixels
pixels.begin();
pixels.show();
pinMode(ledPin, OUTPUT);
// chaseFade
int chase = 0;
uint8_t brightIncrement = 255 / pixels.numPixels();
for (chase; chase < 5; chase++) {
for (i = 0; i < ledNum; i++) {
pixels.setPixelColor(i, Blue, ((i + 1) * brightIncrement));
pixels.show();
delay(DELAY);
pixels.setPixelColor(i, 0, 0, 0);
pixels.show();
delay(1000);
- adafruit_support_rick
You should post the errors you're getting instead of just saying "it doesn't compile".
This line won't compile: There is no setPixelColor function that takes 3 arguments:
- Bazeman
Hi Rick,
Thanks for the reply.
I know that the line in the code won't compile because it is not set in the standard Neopixel library. My question foremost is where exactly I have to put the extra arguments in the .h and .ccp file.
If I'm correct this should be added to .h somewhere:
And this should be added to .ccp somewhere:
Sorry for the noob question.... :-{ But thanks for any help!
setPixelColor(uint16_t n, uint32_t c, uint16_t brightness),
// Set pixel brightness individually using seperate R,G,B components:
void Adafruit_NeoPixel::setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b, uint16_t brightness) {
setPixelColor(n, (brightness*r/255) , (brightness*g/255), (brightness*b/255));
// Set pixel brightness individually using a 'packed' 32-bit RGB color:
void Adafruit_NeoPixel::setPixelColor(uint16_t n, uint32_t c, uint16_t brightness) {
uint8_t
r = (uint8_t)(c >> 16),
g = (uint8_t)(c >> 8),
b = (uint8_t)c;
setPixelColor(n, r, g, b, brightness);
