I'm stuck
Re: I'm stuck
Let's try testing the midi function alone - without the color sensor. The code below is the midi example from the library - I modified it to use pin 10 for the serial communication as you have it wired on the Flora:
  This is an example for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  products from Adafruit!
  BSD license, all text above must be included in any redistribution
#include <SoftwareSerial.h>
// define the pins used
#define VS1053_RX  2 // This is the pin that connects to the RX pin on VS1053
#define VS1053_RESET 9 // This is the pin that connects to the RESET pin on VS1053
// Don't forget to connect the GPIO #0 to GROUND and GPIO #1 pin to 3.3V
// See http://www.vlsi.fi/fileadmin/datasheets/vs1053.pdf Pg 31
#define VS1053_BANK_DEFAULT 0x00
#define VS1053_BANK_DRUMS1 0x78
#define VS1053_BANK_DRUMS2 0x7F
#define VS1053_BANK_MELODY 0x79
// See http://www.vlsi.fi/fileadmin/datasheets/vs1053.pdf Pg 32 for more!
#define VS1053_GM1_OCARINA 80
#define MIDI_NOTE_ON  0x90
#define MIDI_NOTE_OFF 0x80
#define MIDI_CHAN_MSG 0xB0
#define MIDI_CHAN_BANK 0x00
#define MIDI_CHAN_VOLUME 0x07
#define MIDI_CHAN_PROGRAM 0xC0
SoftwareSerial VS1053_MIDI(0, 10); // TX only, do not use the 'rx' side
// on a Mega/Leonardo you may have to change the pin to one that
// software serial support uses OR use a hardware serial port!
  Serial.begin(9600);
  Serial.println("VS1053 MIDI test");
  VS1053_MIDI.begin(31250); // MIDI uses a 'strange baud rate'
  pinMode(VS1053_RESET, OUTPUT);
  digitalWrite(VS1053_RESET, LOW);
  delay(10);
  digitalWrite(VS1053_RESET, HIGH);
  delay(10);
  midiSetChannelBank(0, VS1053_BANK_MELODY);
  midiSetInstrument(0, VS1053_GM1_OCARINA);
  midiSetChannelVolume(0, 127);
  for (uint8_t i=60; i<69; i++) {
    midiNoteOn(0, i, 127);
    delay(100);
    midiNoteOff(0, i, 127);
  delay(1000);
void midiSetInstrument(uint8_t chan, uint8_t inst) {
  if (chan > 15) return;
  inst --; // page 32 has instruments starting with 1 not 0 :(
  if (inst > 127) return;
  VS1053_MIDI.write(MIDI_CHAN_PROGRAM | chan);
  VS1053_MIDI.write(inst);
void midiSetChannelVolume(uint8_t chan, uint8_t vol) {
  if (vol > 127) return;
  VS1053_MIDI.write(MIDI_CHAN_MSG | chan);
  VS1053_MIDI.write(MIDI_CHAN_VOLUME);
  VS1053_MIDI.write(vol);
void midiSetChannelBank(uint8_t chan, uint8_t bank) {
  if (bank > 127) return;
  VS1053_MIDI.write((uint8_t)MIDI_CHAN_BANK);
  VS1053_MIDI.write(bank);
void midiNoteOn(uint8_t chan, uint8_t n, uint8_t vel) {
  if (n > 127) return;
  if (vel > 127) return;
  VS1053_MIDI.write(MIDI_NOTE_ON);
  VS1053_MIDI.write(n);
  VS1053_MIDI.write(vel);
void midiNoteOff(uint8_t chan, uint8_t n, uint8_t vel) {
  VS1053_MIDI.write(MIDI_NOTE_OFF | chan);
talymo
Re: I'm stuck
Post by talymo »
I will try this when I get home.
I disconnected everything and hooked all my parts up to a breadboard so I can test things a little more flexibly and I still got only clicks from the speaker when I interacted with the color sensor, no musical notes.
So, I went ahead and tested the functionality with an Uno and a piezo speaker and I got the sensor unit to interact with the Uno and play a tone through the piezo speaker.
This kind of makes me wonder if there is something wrong with the midi board.
If I have to, I will just keep rolling with the Uno and modify everything to run off that instead of the midi board.
I am at work right now and can't run any tests on the midi board right at the moment, but I will definitely try when I get home tonight.
I know I ran a similar test on the Midi a couple days ago and got nothing, so here's to hoping that this works because I really want this project to work. :)
talymo
Re: I'm stuck
Post by talymo »
adafruit_support_bill wrote:Let's try testing the midi function alone - without the color sensor. The code below is the midi example from the library - I modified it to use pin 10 for the serial communication as you have it wired on the Flora:
  Serial.begin(9600);
  delay(10);
  delay(10);
    delay(100);
  delay(1000);
Ok, got the code test uploaded, everything hooked up and all I get is a rapid series of very faint clicks from the speakers. It sounds like 8 clicks a slight pause then 8 clicks, looping over and over again.
both my color sensor and my neopixel is activated and lit up. The neopixel is a green color.
talymo
Re: I'm stuck
Post by talymo »
Alright, I hooked up the vs1053 board like this example shows...
http://learn.adafruit.com/adafruit-vs10 ... onnections
I still get nothing.
I honestly think it is something to do with the board now.
talymo
Re: I'm stuck
Post by talymo »
uggghhhhh... I'm starting to get so frustrated. :(
I don't know what is wrong with the VS1053 board but no matter what kind of test I try to run on it, nothing comes out. Just static and clicks.
You think the board is damaged? Should I order a new one?
I don't want to order a new one and then the same thing happen though.
What do you suggest?
Re: I'm stuck
Contact support@adafruit.com with a link to this thread for a replacement VS1053 board.
talymo
Re: I'm stuck
Post by talymo »
Do you guys plan to get this board back in stock. It says 5-10 business days on the website but it has been more than that...
ladysputnick
Re: I'm stuck
Post by ladysputnick »
Omg the exact same thing happened to me! I'm stuck exactly there. This project is due on friday, should I really just order another board? Is that what was wrong with your project?
Franklin97355
Re: I'm stuck
Post by Franklin97355 »
You could start your own thread and post the details of what you have and what you've tried along with pictures and diagrams but if you need it by Friday I would order another just to be on the safe side. We will do all we can to help you with your problem. Let us know
