CC3000 no reply on ping
- sketchy
Re: CC3000 no reply on ping
Thank you. I don't know if this is clear, but a couple of things I thought was weird:
1) My mac is and the same subnet as the cc3000. The cc3000 doesn't get results from the ping.
-> I agree, 0 sent looks VERY suspicious.
2) WebClient works - meaning the cc3000 finds www.adafruit.com, sends TCP packets and gets a response.
This strikes me as weird and then I don't understand how the routing can be incorrect if a TCP connection can be made but a ping can't be made? Note: I can ping from terminal to www.adafruit.com.....
One thing for sure, we peel an onion we find a whole 'nother bag of onions to peel - particularly when it comes to networking. But that is the fun of all of this. Frustration -> fixing -> learning...
- berko
if i have an wireless access point that is not listed in TI's list of tested/approved APs what is the chance i will be able to connect?
it is a lynksys E1200.
don't want to buy a cc3000 shield at this point if it is not going to work.
how can i test this or verify it without purchasing one?
what would be different about my access point that would make it not work (i know, like a million things, right)?
thanks for any insight.
best,
jon
best,
jon
- adafruit_support_rick
Honestly, I think the chances of it not working with your AP are very low. LinkSys routers are very mainstream.
- djix123
Just a quick update: it appears the CC3000 boards with firmware 1.24 have the issue fixed with IP addresses in the range 10.0.X.Y
Good. It's nice to get confirmation of that from the field.
Thanks for posting!
Thanks for posting!
- a19i23
I have tried that example and it gets stuck.
Hello, CC3000!
Free RAM: 1215
Initializing...
Connected!
Request DHCP
IP Addr: 10.0.1.23
Netmask: 255.255.255.0
Gateway: 10.0.1.1
DHCPsrv: 10.0.1.1
DNSserv: 10.0.1.1
http://www.adafruit.com -> 207.58.139.247
...and it gets stuck there.
On the buildtest.ino I had to comment out the firmware check for it to work. It says it has version 1.10. Don't know if this is related.
Hello, CC3000!
Free RAM: 1215
Initializing...
Connected!
Request DHCP
IP Addr: 10.0.1.23
Gateway: 10.0.1.1
DHCPsrv: 10.0.1.1
DNSserv: 10.0.1.1
Firmware version 1.10? I don't think we ever shipped that. Did you get this module from Adafruit?
The older firmware versions did not work with 10.x.x.x networks. You should update your firmware. Use the driverpatch_1_12 sketch (driverpatch_1_13 is a beta version, and we don't recommend it).
- adafruit2
if it doesnt pass the firmware test its unlikely its from adafruit - we update the firmware and test each module before shipping.adafruit_support_rick wrote:Firmware version 1.10? I don't think we ever shipped that. Did you get this module from Adafruit?
- a19i23
Yes it is from Adafruit.
- Screen Shot 2014-08-14 at 10.49.54 AM.png (57.48 KiB) Viewed 460 times
Very strange that it would come like that. Can you try installing driverpatch_1_12 from the Adafruit_CC3000_Library?
