Page 1 of 1
Wifi module problems
Posted: Sat Mar 15, 2014 2:29 pm
by vex73
Hi!
I am pretty new with beaglebone and just received Miniature WiFi (802.11b/g/n) module.
I then followed strictly the wifi tutorial step by step.
Everything work well (rtl8192cu installed succesfuly) until dmesg : I don't have the notified line "usbcore : registred new interface driver rtl18192cu".
So then, ifconfig wlan0 doesn't work:
If I type dmesg to see if something is properly detected on my USB Port:
If i type lsusb, it doesn't answer :
It freeze my console, I have to start a new session.
I can see then that some strange things happened typing dmesg :
Anyone faces these kind of problems in the past ?
Re: Wifi module problems
Posted: Sun Mar 16, 2014 1:50 am
by adafruit_support_mike
Wow.. that's a doozy.
All I can say is that something seems to have gone wrong with the driver installation. What OS and version are you using?
Posted: Sun Mar 16, 2014 3:33 am
by vex73
It should answer your question:
Thanks,
Posted: Mon Mar 17, 2014 9:25 pm
That's an older version of the operating system. Try copying the latest version of Angstrom to the BBB's onboard memory: http://beagleboard.org/Getting%20Started#update
Posted: Sat Jun 28, 2014 2:13 pm
by vex73
I was quite busy these time, and tried what you said today. I got now the latest Angstrom version installed on my BeagleBone.
But, still problems. Here is the log:
root@beaglebone:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.8.13 (koen@rrMBP) (gcc version 4.7.3 20130205 (prerelease) (Linaro GCC 4.7-2013.02-01) ) #1 SMP Tue Jun 18 02:11:09 EDT 2013
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 65280
[    0.000000] free_area_init_node: node 0, pgdat c0688d80, node_mem_map c06e4000
[    0.000000]   Normal zone: 512 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 64768 pages, LIFO batch:15
[    0.000000] AM335X ES1.0 (neon )
[    0.000000] PERCPU: Embedded 8 pages/cpu @c08f2000 s9408 r8192 d15168 u32768
[    0.000000] pcpu-alloc: s9408 r8192 d15168 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 64768
[    0.000000] Kernel command line: console=ttyO0,115200n8 run_hardware_tests quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] __ex_table already sorted, skipping sort
[    0.000000] allocated 524288 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 255MB = 255MB total
[    0.000000] Memory: 251176k/251176k available, 10968k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xd0800000 - 0xff000000   ( 744 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf800000 - 0xbfe00000   (   6 MB)
      .text : 0xc0008000 - 0xc05d5914   (5943 kB)
      .init : 0xc05d6000 - 0xc06174c0   ( 262 kB)
      .data : 0xc0618000 - 0xc0689ca0   ( 456 kB)
       .bss : 0xc0689ca0 - 0xc06e36bc   ( 359 kB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[    0.000000] Console: colour dummy device 80x30
[    0.000364] Calibrating delay loop... 545.07 BogoMIPS (lpj=531968)
[    0.015419] pid_max: default: 32768 minimum: 301
[    0.015650] Security Framework initialized
[    0.015750] Mount-cache hash table entries: 512
[    0.025792] Initializing cgroup subsys cpuacct
[    0.025829] Initializing cgroup subsys memory
[    0.025893] Initializing cgroup subsys blkio
[    0.026035] CPU: Testing write buffer coherency: ok
[    0.026599] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.026681] Setting up static identity map for 0x80370ee0 - 0x80370f2c
[    0.028115] Brought up 1 CPUs
[    0.028141] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[    0.029478] devtmpfs: initialized
[    0.094467] pinctrl core: initialized pinctrl subsystem
[    0.094689] rstctl core: initialized rstctl subsystem
[    0.095189] regulator-dummy: no parameters
[    0.095781] NET: Registered protocol family 16
[    0.096693] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.106659] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.107497] platform 49000000.edma: alias fck already exists
[    0.107531] platform 49000000.edma: alias fck already exists
[    0.107558] platform 49000000.edma: alias fck already exists
[    0.108725] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[    0.108910] OMAP GPIO hardware version 0.1
[    0.110341] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[    0.111669] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[    0.112974] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[    0.118693] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.120929] cpsw.0: No hwaddr in dt. Using 50:56:63:c9:d0:01 from efuse
[    0.120975] cpsw.1: No hwaddr in dt. Using 50:56:63:c9:d0:02 from efuse
[    0.135515] bio: create slab <bio-0> at 0
[    0.147581] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.147814] of_get_named_gpio_flags: can't parse gpios property
[    0.148069] vmmcsd_fixed: 3300 mV
[    0.150974] SCSI subsystem initialized
[    0.151385] usbcore: registered new interface driver usbfs
[    0.151509] usbcore: registered new interface driver hub
[    0.151805] usbcore: registered new device driver usb
[    0.153901] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    0.155443] input: tps65217_pwr_but as /devices/ocp.2/44e0b000.i2c/i2c-0/0-0024/input/input0
[    0.157224] DCDC1: at 1800 mV
[    0.158382] vdd_mpu: 925 <--> 1325 mV at 1275 mV
[    0.159502] vdd_core: 925 <--> 1150 mV at 1100 mV
[    0.160687] LDO1: at 1800 mV
[    0.161767] LDO2: at 3300 mV
[    0.162942] LDO3: 1800 <--> 3300 mV at 3300 mV
[    0.164099] LDO4: at 3300 mV
[    0.165117] tps65217 0-0024: TPS65217 ID 0xf version 1.1
[    0.165905] omap_i2c 44e0b000.i2c: unable to select pin group
[    0.166638] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[    0.169049] omap_i2c 4819c000.i2c: unable to select pin group
[    0.169278] media: Linux media interface: v0.10
[    0.169383] Linux video capture interface: v2.00
[    0.170179] Advanced Linux Sound Architecture Driver Initialized.
[    0.171544] Switching to clocksource gp_timer
[    0.189828] NET: Registered protocol family 2
[    0.190859] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    0.190948] TCP bind hash table entries: 2048 (order: 3, 40960 bytes)
[    0.191039] TCP: Hash tables configured (established 2048 bind 2048)
[    0.191130] TCP: reno registered
[    0.191231] UDP hash table entries: 256 (order: 1, 12288 bytes)
[    0.191282] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[    0.191718] NET: Registered protocol family 1
[    0.192303] RPC: Registered named UNIX socket transport module.
[    0.192323] RPC: Registered udp transport module.
[    0.192337] RPC: Registered tcp transport module.
[    0.192350] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.193596] CPU PMU: probing PMU on CPU 0
[    0.193627] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[    0.194090] omap2_mbox_probe: platform not supported
[    0.198075] VFS: Disk quotas dquot_6.5.2
[    0.198313] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.199628] NFS: Registering the id_resolver key type
[    0.199736] Key type id_resolver registered
[    0.199754] Key type id_legacy registered
[    0.199827] jffs2: version 2.2. (NAND) (SUMMARY)  \xffffffc2\xffffffa9 2001-2006 Red Hat, Inc.
[    0.200267] msgmni has been set to 490
[    0.203252] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.203279] io scheduler noop registered
[    0.203295] io scheduler deadline registered
[    0.203336] io scheduler cfq registered (default)
[    0.205057] tps65217-bl tps65217-bl: no platform data provided
[    0.205102] tps65217-bl: probe of tps65217-bl failed with error -22
[    0.205993] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.208625] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[    0.209022] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[    0.221261] console [ttyO0] enabled
[    0.222288] [drm] Initialized drm 1.1.0 20060810
[    0.236221] brd: module loaded
[    0.243280] loop: module loaded
[    0.243409] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    0.243487] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    0.243558] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    0.243627] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    0.243696] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    0.250909] bone-capemgr bone_capemgr.7: Baseboard: 'A335BONE,00A6,3712BB000826'
[    0.250948] bone-capemgr bone_capemgr.7: compatible-baseboard=ti,beaglebone
[    0.281054] bone-capemgr bone_capemgr.7: slot #0: No cape found
[    0.318160] bone-capemgr bone_capemgr.7: slot #1: No cape found
[    0.355269] bone-capemgr bone_capemgr.7: slot #2: No cape found
[    0.392377] bone-capemgr bone_capemgr.7: slot #3: No cape found
[    0.398777] bone-capemgr bone_capemgr.7: initialized OK.
[    0.400774] OneNAND driver initializing
[    0.402318] usbcore: registered new interface driver asix
[    0.402444] usbcore: registered new interface driver cdc_ether
[    0.402564] usbcore: registered new interface driver smsc95xx
[    0.402666] usbcore: registered new interface driver net1080
[    0.402756] usbcore: registered new interface driver cdc_subset
[    0.402843] usbcore: registered new interface driver zaurus
[    0.403008] usbcore: registered new interface driver cdc_ncm
[    0.403813] usbcore: registered new interface driver cdc_acm
[    0.403832] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.403846] Initializing USB Mass Storage driver...
[    0.403979] usbcore: registered new interface driver usb-storage
[    0.403994] USB Mass Storage support registered.
[    0.404229] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.404623] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[    0.404651] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[    0.404689] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[    0.404710] musb-hdrc: MHDRC RTL version 2.0
[    0.404725] musb-hdrc: setup fifo_mode 4
[    0.404753] musb-hdrc: 28/31 max ep, 16384/16384 memory
[    0.404900] musb-hdrc musb-hdrc.0.auto: *** mode=3
[    0.404922] musb-hdrc musb-hdrc.0.auto: *** power=250
[    0.405650] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[    0.405678] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[    0.405714] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[    0.405733] musb-hdrc: MHDRC RTL version 2.0
[    0.405747] musb-hdrc: setup fifo_mode 4
[    0.405769] musb-hdrc: 28/31 max ep, 16384/16384 memory
[    0.405896] musb-hdrc musb-hdrc.1.auto: *** mode=1
[    0.405918] musb-hdrc musb-hdrc.1.auto: *** power=250
[    0.405939] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    0.406382] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    0.406423] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup
[    0.406539] usb usb1: default language 0x0409
[    0.406598] usb usb1: udev 1, busnum 1, minor = 0
[    0.406622] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.406644] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.406665] usb usb1: Product: MUSB HDRC host driver
[    0.406685] usb usb1: Manufacturer: Linux 3.8.13 musb-hcd
[    0.406704] usb usb1: SerialNumber: musb-hdrc.1.auto
[    0.407486] usb usb1: usb_probe_device
[    0.407515] usb usb1: configuration #1 chosen from 1 choice
[    0.407585] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[    0.407792] hub 1-0:1.0: usb_probe_interface
[    0.407815] hub 1-0:1.0: usb_probe_interface - got id
[    0.407844] hub 1-0:1.0: USB hub found
[    0.407885] hub 1-0:1.0: 1 port detected
[    0.407904] hub 1-0:1.0: standalone hub
[    0.407921] hub 1-0:1.0: individual port power switching
[    0.407939] hub 1-0:1.0: no over-current protection
[    0.408051] hub 1-0:1.0: Single TT
[    0.408075] hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
[    0.408095] hub 1-0:1.0: power on to power good time: 10ms
[    0.408180] hub 1-0:1.0: local power source is good
[    0.408295] hub 1-0:1.0: enabling power on all ports
[    0.409416] mousedev: PS/2 mouse device common for all mice
[    0.412032] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[    0.412095] 44e3e000.rtc: already running
[    0.412369] i2c /dev entries driver
[    0.414129] Driver for 1-wire Dallas network protocol.
[    0.415564] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    0.415966] cpuidle: using governor ladder
[    0.415985] cpuidle: using governor menu
[    0.416394] of_get_named_gpio_flags: can't parse gpios property
[    0.416413] of_get_named_gpio_flags: can't parse gpios property
[    0.416429] of_get_named_gpio_flags: can't parse gpios property
[    0.416465] omap_hsmmc mmc.3: of_parse_phandle_with_args of 'reset' failed
[    0.423708] omap_hsmmc mmc.3: Failed to get rstctl; not using any
[    0.423761] omap_hsmmc mmc.3: unable to select pin group
[    0.424045] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[    0.424122] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[    0.424654] mmc.3 supply vmmc_aux not found, using dummy regulator
[    0.426177] omap_hsmmc mmc.3: pins are not configured from the driver
[    0.455445] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.6
[    0.467204] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.6) status -22
[    0.474518] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[    0.483511] leds-gpio gpio-leds.6: pins are not configured from the driver
[    0.483550] of_get_named_gpio_flags exited with status 53
[    0.483573] of_get_named_gpio_flags exited with status 54
[    0.483595] of_get_named_gpio_flags exited with status 55
[    0.483617] of_get_named_gpio_flags exited with status 56
[    0.483642] of_get_named_gpio_flags exited with status 53
[    0.483934] of_get_named_gpio_flags exited with status 54
[    0.484195] of_get_named_gpio_flags exited with status 55
[    0.484398] of_get_named_gpio_flags exited with status 56
[    0.484765] ledtrig-cpu: registered to indicate activity on CPUs
[    0.485200] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[    0.485280] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    0.487560] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    0.487689] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[    0.487763] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[    0.488954] usbcore: registered new interface driver usbhid
[    0.488973] usbhid: USB HID core driver
[    0.491747] TCP: cubic registered
[    0.491769] Initializing XFRM netlink socket
[    0.491815] NET: Registered protocol family 17
[    0.491895] NET: Registered protocol family 15
[    0.492357] Key type dns_resolver registered
[    0.492694] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.492734] ThumbEE CPU extension supported.
[    0.492778] Registering SWP/SWPB emulation handler
[    0.493752] registered taskstats version 1
[    0.511431] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[    0.511630] hub 1-0:1.0: hub_suspend
[    0.511676] usb usb1: bus auto-suspend, wakeup 1
[    0.544708] mmc0: host does not support reading read-only switch. assuming write-enable.
[    0.546694] mmc0: new high speed SDHC card at address 1234
[    0.547458] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    0.547483] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[    0.547961] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[    0.549727] libphy: 4a101000.mdio: probed
[    0.549760] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    0.549988] Detected MACID = 50:56:63:c9:d0:01
[    0.550118] cpsw 4a100000.ethernet: NAPI disabled
[    0.550827]  mmcblk0: p1 p2
[    0.553362] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:19:09 UTC (946685949)
[    0.562203] ALSA device list:
[    0.562230]   No soundcards found.
[    0.593840] usb usb1: usb wakeup-resume
[    0.593894] usb usb1: usb auto-resume
[    0.593959] hub 1-0:1.0: hub_resume
[    0.594010] hub 1-0:1.0: port 1: status 0101 change 0001
[    0.597037] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    0.597118] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    0.624488] devtmpfs: mounted
[    0.624917] Freeing init memory: 260K
[    0.697145] hub 1-0:1.0: state 7 ports 1 chg 0002 evt 0000
[    0.697241] hub 1-0:1.0: port 1, status 0101, change 0000, 12 Mb/s
[    0.802697] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[    0.922507] usb 1-1: default language 0x0409
[    0.923116] usb 1-1: udev 2, busnum 1, minor = 1
[    0.923138] usb 1-1: New USB device found, idVendor=0bda, idProduct=8176
[    0.923156] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    0.923172] usb 1-1: Product: 802.11n WLAN Adapter
[    0.923187] usb 1-1: Manufacturer: Realtek
[    0.923201] usb 1-1: SerialNumber: 00e04c000001
[    0.923837] usb 1-1: usb_probe_device
[    0.923863] usb 1-1: configuration #1 chosen from 1 choice
[    0.924020] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[    0.924926] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[    0.924968] hub 1-0:1.0: port 1 enable change, status 00000503
[    1.498593] systemd[1]: systemd 196 running in system mode. (+PAM -LIBWRAP -AUDIT -SELINUX +IMA +SYSVINIT -LIBCRYPTSETUP +GCRYPT +ACL +XZ; angstrom)
[    1.592272] systemd[1]: Inserted module 'autofs4'
[    1.594666] systemd[1]: Set hostname to <beaglebone>.
[    1.624448] systemd[1]: Initializing machine ID from random generator.
[    1.624958] systemd[1]: Installed transient /etc/machine-id file.
[    1.970771] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    1.971379] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    1.971520] systemd[1]: Expecting device dev-ttyGS0.device...
[    1.971634] systemd[1]: Expecting device dev-ttyO0.device...
[    1.971736] systemd[1]: Starting Remote File Systems.
[    1.971828] systemd[1]: Reached target Remote File Systems.
[    1.971931] systemd[1]: Starting Delayed Shutdown Socket.
[    1.972202] systemd[1]: Listening on Delayed Shutdown Socket.
[    1.972292] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    1.972657] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    1.972796] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    1.973138] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    1.973466] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    1.974350] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    1.975203] systemd[1]: Starting udev Kernel Socket.
[    1.975488] systemd[1]: Listening on udev Kernel Socket.
[    1.975965] systemd[1]: Starting udev Control Socket.
[    1.976289] systemd[1]: Listening on udev Control Socket.
[    1.976553] systemd[1]: Starting Swap.
[    1.976658] systemd[1]: Reached target Swap.
[    1.976779] systemd[1]: Starting Journal Socket.
[    1.977232] systemd[1]: Listening on Journal Socket.
[    1.977437] systemd[1]: Starting File System Check on Root Device...
[    1.985745] systemd[1]: Starting udev Coldplug all Devices...
[    1.995960] systemd[1]: Mounting Debug File System...
[    2.036200] systemd[1]: Started Set Up Additional Binary Formats.
[    2.104008] systemd[1]: Starting Apply Kernel Variables...
[    2.125245] systemd[1]: Starting Load Kernel Modules...
[    2.131466] systemd[1]: Mounted Huge Pages File System.
[    2.131640] systemd[1]: Started Machine ID first boot configure.
[    2.131811] systemd[1]: Mounting POSIX Message Queue File System...
[    2.140121] systemd[1]: Starting udev Kernel Device Manager...
[    2.152771] systemd[1]: Starting Journal Service...
[    2.159125] systemd[1]: Started Journal Service.
[    2.342974] systemd-udevd[85]: starting version 196
[    2.538228] bluetooth: disagrees about version of symbol skb_free_datagram
[    2.538263] bluetooth: Unknown symbol skb_free_datagram (err -22)
[    2.538311] bluetooth: disagrees about version of symbol simple_attr_write
[    2.538324] bluetooth: Unknown symbol simple_attr_write (err -22)
[    2.538359] bluetooth: disagrees about version of symbol sock_i_uid
[    2.538372] bluetooth: Unknown symbol sock_i_uid (err -22)
[    2.538414] bluetooth: disagrees about version of symbol simple_attr_open
[    2.538428] bluetooth: Unknown symbol simple_attr_open (err -22)
[    2.539131] bluetooth: disagrees about version of symbol skb_put
[    2.539154] bluetooth: Unknown symbol skb_put (err -22)
[    2.539198] bluetooth: disagrees about version of symbol dev_set_name
[    2.539211] bluetooth: Unknown symbol dev_set_name (err -22)
[    2.539282] bluetooth: disagrees about version of symbol skb_dequeue
[    2.539295] bluetooth: Unknown symbol skb_dequeue (err -22)
[    2.539374] bluetooth: disagrees about version of symbol device_initialize
[    2.539387] bluetooth: Unknown symbol device_initialize (err -22)
[    2.539524] bluetooth: disagrees about version of symbol sock_no_connect
[    2.539538] bluetooth: Unknown symbol sock_no_connect (err -22)
[    2.539589] bluetooth: disagrees about version of symbol get_device
[    2.539602] bluetooth: Unknown symbol get_device (err -22)
[    2.539635] bluetooth: disagrees about version of symbol skb_copy_datagram_iovec
[    2.539648] bluetooth: Unknown symbol skb_copy_datagram_iovec (err -22)
[    2.539683] bluetooth: disagrees about version of symbol sock_alloc_send_skb
[    2.539696] bluetooth: Unknown symbol sock_alloc_send_skb (err -22)
[    2.539752] bluetooth: disagrees about version of symbol proto_unregister
[    2.539765] bluetooth: Unknown symbol proto_unregister (err -22)
[    2.539783] bluetooth: disagrees about version of symbol kfree_skb
[    2.539795] bluetooth: Unknown symbol kfree_skb (err -22)
[    2.539827] bluetooth: disagrees about version of symbol sock_register
[    2.539841] bluetooth: Unknown symbol sock_register (err -22)
[    2.539879] bluetooth: disagrees about version of symbol datagram_poll
[    2.539892] bluetooth: Unknown symbol datagram_poll (err -22)
[    2.539911] bluetooth: disagrees about version of symbol sock_get_timestampns
[    2.539924] bluetooth: Unknown symbol sock_get_timestampns (err -22)
[    2.539945] bluetooth: disagrees about version of symbol put_device
[    2.539958] bluetooth: Unknown symbol put_device (err -22)
[    2.539989] bluetooth: disagrees about version of symbol __alloc_skb
[    2.540002] bluetooth: Unknown symbol __alloc_skb (err -22)
[    2.540033] bluetooth: disagrees about version of symbol sk_reset_timer
[    2.540046] bluetooth: Unknown symbol sk_reset_timer (err -22)
[    2.540073] bluetooth: disagrees about version of symbol proto_register
[    2.540086] bluetooth: Unknown symbol proto_register (err -22)
[    2.540116] bluetooth: disagrees about version of symbol skb_queue_tail
[    2.540129] bluetooth: Unknown symbol skb_queue_tail (err -22)
[    2.540163] bluetooth: disagrees about version of symbol __sock_recv_ts_and_drops
[    2.540176] bluetooth: Unknown symbol __sock_recv_ts_and_drops (err -22)
[    2.540212] bluetooth: disagrees about version of symbol __sock_recv_timestamp
[    2.540225] bluetooth: Unknown symbol __sock_recv_timestamp (err -22)
[    2.540244] bluetooth: disagrees about version of symbol sock_no_shutdown
[    2.540257] bluetooth: Unknown symbol sock_no_shutdown (err -22)
[    2.540288] bluetooth: disagrees about version of symbol init_net
[    2.540301] bluetooth: Unknown symbol init_net (err -22)
[    2.540333] bluetooth: disagrees about version of symbol skb_pull
[    2.540346] bluetooth: Unknown symbol skb_pull (err -22)
[    2.540365] bluetooth: disagrees about version of symbol device_add
[    2.540378] bluetooth: Unknown symbol device_add (err -22)
[    2.540399] bluetooth: disagrees about version of symbol simple_attr_release
[    2.540412] bluetooth: Unknown symbol simple_attr_release (err -22)
[    2.540452] bluetooth: disagrees about version of symbol sk_free
[    2.540465] bluetooth: Unknown symbol sk_free (err -22)
[    2.540484] bluetooth: disagrees about version of symbol device_move
[    2.540497] bluetooth: Unknown symbol device_move (err -22)
[    2.540515] bluetooth: disagrees about version of symbol sock_no_accept
[    2.540528] bluetooth: Unknown symbol sock_no_accept (err -22)
[    2.540579] bluetooth: disagrees about version of symbol skb_push
[    2.540592] bluetooth: Unknown symbol skb_push (err -22)
[    2.540625] bluetooth: disagrees about version of symbol sock_no_listen
[    2.540638] bluetooth: Unknown symbol sock_no_listen (err -22)
[    2.540749] bluetooth: disagrees about version of symbol proc_net_remove
[    2.540849] bluetooth: Unknown symbol proc_net_remove (err -22)
[    2.548776] bluetooth: disagrees about version of symbol lock_sock_nested
[    2.548808] bluetooth: Unknown symbol lock_sock_nested (err -22)
[    2.548849] bluetooth: disagrees about version of symbol device_find_child
[    2.548862] bluetooth: Unknown symbol device_find_child (err -22)
[    2.548919] bluetooth: disagrees about version of symbol __pskb_copy
[    2.548932] bluetooth: Unknown symbol __pskb_copy (err -22)
[    2.548952] bluetooth: disagrees about version of symbol sk_alloc
[    2.548965] bluetooth: Unknown symbol sk_alloc (err -22)
[    2.548983] bluetooth: disagrees about version of symbol device_del
[    2.548996] bluetooth: Unknown symbol device_del (err -22)
[    2.549020] bluetooth: disagrees about version of symbol __sock_recv_wifi_status
[    2.549033] bluetooth: Unknown symbol __sock_recv_wifi_status (err -22)
[    2.549064] bluetooth: disagrees about version of symbol sock_no_socketpair
[    2.549077] bluetooth: Unknown symbol sock_no_socketpair (err -22)
[    2.549103] bluetooth: disagrees about version of symbol skb_queue_purge
[    2.549116] bluetooth: Unknown symbol skb_queue_purge (err -22)
[    2.549164] bluetooth: disagrees about version of symbol sock_no_mmap
[    2.549178] bluetooth: Unknown symbol sock_no_mmap (err -22)
[    2.549205] bluetooth: disagrees about version of symbol sock_get_timestamp
[    2.549218] bluetooth: Unknown symbol sock_get_timestamp (err -22)
[    2.549241] bluetooth: disagrees about version of symbol simple_attr_read
[    2.549253] bluetooth: Unknown symbol simple_attr_read (err -22)
[    2.549280] bluetooth: disagrees about version of symbol skb_trim
[    2.549292] bluetooth: Unknown symbol skb_trim (err -22)
[    2.549308] bluetooth: disagrees about version of symbol skb_unlink
[    2.549321] bluetooth: Unknown symbol skb_unlink (err -22)
[    2.549350] bluetooth: disagrees about version of symbol proc_net_fops_create
[    2.549363] bluetooth: Unknown symbol proc_net_fops_create (err -22)
[    2.549407] bluetooth: disagrees about version of symbol sock_i_ino
[    2.549420] bluetooth: Unknown symbol sock_i_ino (err -22)
[    2.549507] bluetooth: disagrees about version of symbol skb_recv_datagram
[    2.549520] bluetooth: Unknown symbol skb_recv_datagram (err -22)
[    2.549553] bluetooth: disagrees about version of symbol sock_queue_rcv_skb
[    2.549566] bluetooth: Unknown symbol sock_queue_rcv_skb (err -22)
[    2.549616] bluetooth: disagrees about version of symbol skb_copy
[    2.549629] bluetooth: Unknown symbol skb_copy (err -22)
[    2.549650] bluetooth: disagrees about version of symbol skb_clone
[    2.549663] bluetooth: Unknown symbol skb_clone (err -22)
[    2.549714] bluetooth: disagrees about version of symbol sk_stop_timer
[    2.549728] bluetooth: Unknown symbol sk_stop_timer (err -22)
[    2.549822] bluetooth: disagrees about version of symbol sock_init_data
[    2.549835] bluetooth: Unknown symbol sock_init_data (err -22)
[    2.549859] bluetooth: disagrees about version of symbol release_sock
[    2.549872] bluetooth: Unknown symbol release_sock (err -22)
[    2.549885] bluetooth: disagrees about version of symbol skb_queue_head
[    2.549898] bluetooth: Unknown symbol skb_queue_head (err -22)
[    2.692652] NET: Registered protocol family 10
[    2.752642] NET: Registered protocol family 23
[    2.765894] IrCOMM protocol (Dag Brattli)
[    2.841826] bluetooth: disagrees about version of symbol skb_free_datagram
[    2.841858] bluetooth: Unknown symbol skb_free_datagram (err -22)
[    2.841904] bluetooth: disagrees about version of symbol simple_attr_write
[    2.841918] bluetooth: Unknown symbol simple_attr_write (err -22)
[    2.841953] bluetooth: disagrees about version of symbol sock_i_uid
[    2.841966] bluetooth: Unknown symbol sock_i_uid (err -22)
[    2.842007] bluetooth: disagrees about version of symbol simple_attr_open
[    2.842020] bluetooth: Unknown symbol simple_attr_open (err -22)
[    2.842118] bluetooth: disagrees about version of symbol skb_put
[    2.842131] bluetooth: Unknown symbol skb_put (err -22)
[    2.842171] bluetooth: disagrees about version of symbol dev_set_name
[    2.842184] bluetooth: Unknown symbol dev_set_name (err -22)
[    2.842252] bluetooth: disagrees about version of symbol skb_dequeue
[    2.842266] bluetooth: Unknown symbol skb_dequeue (err -22)
[    2.842343] bluetooth: disagrees about version of symbol device_initialize
[    2.842356] bluetooth: Unknown symbol device_initialize (err -22)
[    2.842494] bluetooth: disagrees about version of symbol sock_no_connect
[    2.842507] bluetooth: Unknown symbol sock_no_connect (err -22)
[    2.842559] bluetooth: disagrees about version of symbol get_device
[    2.842572] bluetooth: Unknown symbol get_device (err -22)
[    2.842605] bluetooth: disagrees about version of symbol skb_copy_datagram_iovec
[    2.842618] bluetooth: Unknown symbol skb_copy_datagram_iovec (err -22)
[    2.842651] bluetooth: disagrees about version of symbol sock_alloc_send_skb
[    2.842664] bluetooth: Unknown symbol sock_alloc_send_skb (err -22)
[    2.842719] bluetooth: disagrees about version of symbol proto_unregister
[    2.842732] bluetooth: Unknown symbol proto_unregister (err -22)
[    2.842750] bluetooth: disagrees about version of symbol kfree_skb
[    2.842763] bluetooth: Unknown symbol kfree_skb (err -22)
[    2.842793] bluetooth: disagrees about version of symbol sock_register
[    2.842806] bluetooth: Unknown symbol sock_register (err -22)
[    2.842844] bluetooth: disagrees about version of symbol datagram_poll
[    2.842856] bluetooth: Unknown symbol datagram_poll (err -22)
[    2.842875] bluetooth: disagrees about version of symbol sock_get_timestampns
[    2.842888] bluetooth: Unknown symbol sock_get_timestampns (err -22)
[    2.842909] bluetooth: disagrees about version of symbol put_device
[    2.842922] bluetooth: Unknown symbol put_device (err -22)
[    2.842952] bluetooth: disagrees about version of symbol __alloc_skb
[    2.842965] bluetooth: Unknown symbol __alloc_skb (err -22)
[    2.842995] bluetooth: disagrees about version of symbol sk_reset_timer
[    2.843008] bluetooth: Unknown symbol sk_reset_timer (err -22)
[    2.843035] bluetooth: disagrees about version of symbol proto_register
[    2.843048] bluetooth: Unknown symbol proto_register (err -22)
[    2.843079] bluetooth: disagrees about version of symbol skb_queue_tail
[    2.843092] bluetooth: Unknown symbol skb_queue_tail (err -22)
[    2.843126] bluetooth: disagrees about version of symbol __sock_recv_ts_and_drops
[    2.843139] bluetooth: Unknown symbol __sock_recv_ts_and_drops (err -22)
[    2.843175] bluetooth: disagrees about version of symbol __sock_recv_timestamp
[    2.843188] bluetooth: Unknown symbol __sock_recv_timestamp (err -22)
[    2.843207] bluetooth: disagrees about version of symbol sock_no_shutdown
[    2.843220] bluetooth: Unknown symbol sock_no_shutdown (err -22)
[    2.843250] bluetooth: disagrees about version of symbol init_net
[    2.843263] bluetooth: Unknown symbol init_net (err -22)
[    2.843294] bluetooth: disagrees about version of symbol skb_pull
[    2.843307] bluetooth: Unknown symbol skb_pull (err -22)
[    2.843327] bluetooth: disagrees about version of symbol device_add
[    2.843340] bluetooth: Unknown symbol device_add (err -22)
[    2.843360] bluetooth: disagrees about version of symbol simple_attr_release
[    2.843373] bluetooth: Unknown symbol simple_attr_release (err -22)
[    2.843412] bluetooth: disagrees about version of symbol sk_free
[    2.843425] bluetooth: Unknown symbol sk_free (err -22)
[    2.843445] bluetooth: disagrees about version of symbol device_move
[    2.843457] bluetooth: Unknown symbol device_move (err -22)
[    2.843476] bluetooth: disagrees about version of symbol sock_no_accept
[    2.843489] bluetooth: Unknown symbol sock_no_accept (err -22)
[    2.851525] bluetooth: disagrees about version of symbol skb_push
[    2.851554] bluetooth: Unknown symbol skb_push (err -22)
[    2.851599] bluetooth: disagrees about version of symbol sock_no_listen
[    2.851613] bluetooth: Unknown symbol sock_no_listen (err -22)
[    2.851741] bluetooth: disagrees about version of symbol proc_net_remove
[    2.851756] bluetooth: Unknown symbol proc_net_remove (err -22)
[    2.851785] bluetooth: disagrees about version of symbol lock_sock_nested
[    2.851797] bluetooth: Unknown symbol lock_sock_nested (err -22)
[    2.851827] bluetooth: disagrees about version of symbol device_find_child
[    2.851840] bluetooth: Unknown symbol device_find_child (err -22)
[    2.851905] bluetooth: disagrees about version of symbol __pskb_copy
[    2.851919] bluetooth: Unknown symbol __pskb_copy (err -22)
[    2.854889] bluetooth: disagrees about version of symbol sk_alloc
[    2.854922] bluetooth: Unknown symbol sk_alloc (err -22)
[    2.854950] bluetooth: disagrees about version of symbol device_del
[    2.854963] bluetooth: Unknown symbol device_del (err -22)
[    2.854989] bluetooth: disagrees about version of symbol __sock_recv_wifi_status
[    2.855003] bluetooth: Unknown symbol __sock_recv_wifi_status (err -22)
[    2.855034] bluetooth: disagrees about version of symbol sock_no_socketpair
[    2.855047] bluetooth: Unknown symbol sock_no_socketpair (err -22)
[    2.855076] bluetooth: disagrees about version of symbol skb_queue_purge
[    2.855089] bluetooth: Unknown symbol skb_queue_purge (err -22)
[    2.855139] bluetooth: disagrees about version of symbol sock_no_mmap
[    2.855152] bluetooth: Unknown symbol sock_no_mmap (err -22)
[    2.855180] bluetooth: disagrees about version of symbol sock_get_timestamp
[    2.855193] bluetooth: Unknown symbol sock_get_timestamp (err -22)
[    2.855388] bluetooth: disagrees about version of symbol simple_attr_read
[    2.855407] bluetooth: Unknown symbol simple_attr_read (err -22)
[    2.856296] bluetooth: disagrees about version of symbol skb_trim
[    2.856321] bluetooth: Unknown symbol skb_trim (err -22)
[    2.856338] bluetooth: disagrees about version of symbol skb_unlink
[    2.856351] bluetooth: Unknown symbol skb_unlink (err -22)
[    2.856387] bluetooth: disagrees about version of symbol proc_net_fops_create
[    2.856400] bluetooth: Unknown symbol proc_net_fops_create (err -22)
[    2.856448] bluetooth: disagrees about version of symbol sock_i_ino
[    2.856461] bluetooth: Unknown symbol sock_i_ino (err -22)
[    2.856572] bluetooth: disagrees about version of symbol skb_recv_datagram
[    2.856586] bluetooth: Unknown symbol skb_recv_datagram (err -22)
[    2.856620] bluetooth: disagrees about version of symbol sock_queue_rcv_skb
[    2.856633] bluetooth: Unknown symbol sock_queue_rcv_skb (err -22)
[    2.856686] bluetooth: disagrees about version of symbol skb_copy
[    2.856699] bluetooth: Unknown symbol skb_copy (err -22)
[    2.856720] bluetooth: disagrees about version of symbol skb_clone
[    2.856733] bluetooth: Unknown symbol skb_clone (err -22)
[    2.856787] bluetooth: disagrees about version of symbol sk_stop_timer
[    2.856800] bluetooth: Unknown symbol sk_stop_timer (err -22)
[    2.856897] bluetooth: disagrees about version of symbol sock_init_data
[    2.856911] bluetooth: Unknown symbol sock_init_data (err -22)
[    2.856936] bluetooth: disagrees about version of symbol release_sock
[    2.856949] bluetooth: Unknown symbol release_sock (err -22)
[    2.856962] bluetooth: disagrees about version of symbol skb_queue_head
[    2.856975] bluetooth: Unknown symbol skb_queue_head (err -22)
[    3.121084] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    3.865424] systemd-journald[86]: Received SIGUSR1
[    9.328217] cfg80211: Calling CRDA to update world regulatory domain
[    9.328359] cfg80211: World regulatory domain updated:
[    9.328372] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[    9.328388] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    9.328402] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    9.328416] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[    9.328429] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    9.328443] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   10.618412] rtlwifi: disagrees about version of symbol skb_put
[   10.618447] rtlwifi: Unknown symbol skb_put (err -22)
[   10.618498] rtlwifi: disagrees about version of symbol skb_dequeue
[   10.618513] rtlwifi: Unknown symbol skb_dequeue (err -22)
[   10.618537] rtlwifi: disagrees about version of symbol ieee80211_free_hw
[   10.618551] rtlwifi: Unknown symbol ieee80211_free_hw (err -22)
[   10.618573] rtlwifi: disagrees about version of symbol ieee80211_alloc_hw
[   10.618587] rtlwifi: Unknown symbol ieee80211_alloc_hw (err -22)
[   10.618636] rtlwifi: disagrees about version of symbol regulatory_hint
[   10.618649] rtlwifi: Unknown symbol regulatory_hint (err -22)
[   10.618682] rtlwifi: disagrees about version of symbol ieee80211_register_hw
[   10.618696] rtlwifi: Unknown symbol ieee80211_register_hw (err -22)
[   10.618798] rtlwifi: disagrees about version of symbol ieee80211_rate_control_unregister
[   10.618816] rtlwifi: Unknown symbol ieee80211_rate_control_unregister (err -22)
[   10.619322] rtlwifi: disagrees about version of symbol ieee80211_get_hdrlen_from_skb
[   10.619346] rtlwifi: Unknown symbol ieee80211_get_hdrlen_from_skb (err -22)
[   10.619401] rtlwifi: disagrees about version of symbol kfree_skb
[   10.619415] rtlwifi: Unknown symbol kfree_skb (err -22)
[   10.619435] rtlwifi: disagrees about version of symbol ieee80211_tx_status_irqsafe
[   10.619449] rtlwifi: Unknown symbol ieee80211_tx_status_irqsafe (err -22)
[   10.619496] rtlwifi: disagrees about version of symbol wiphy_rfkill_set_hw_state
[   10.619510] rtlwifi: Unknown symbol wiphy_rfkill_set_hw_state (err -22)
[   10.619579] rtlwifi: disagrees about version of symbol dev_kfree_skb_irq
[   10.619593] rtlwifi: Unknown symbol dev_kfree_skb_irq (err -22)
[   10.619620] rtlwifi: disagrees about version of symbol wiphy_to_ieee80211_hw
[   10.619634] rtlwifi: Unknown symbol wiphy_to_ieee80211_hw (err -22)
[   10.619650] rtlwifi: disagrees about version of symbol dev_kfree_skb_any
[   10.619664] rtlwifi: Unknown symbol dev_kfree_skb_any (err -22)
[   10.619690] rtlwifi: disagrees about version of symbol wiphy_rfkill_stop_polling
[   10.619704] rtlwifi: Unknown symbol wiphy_rfkill_stop_polling (err -22)
[   10.619721] rtlwifi: disagrees about version of symbol skb_pull
[   10.619735] rtlwifi: Unknown symbol skb_pull (err -22)
[   10.619768] rtlwifi: disagrees about version of symbol wiphy_apply_custom_regulatory
[   10.619782] rtlwifi: Unknown symbol wiphy_apply_custom_regulatory (err -22)
[   10.619823] rtlwifi: disagrees about version of symbol ieee80211_rate_control_register
[   10.619837] rtlwifi: Unknown symbol ieee80211_rate_control_register (err -22)
[   10.619932] rtlwifi: disagrees about version of symbol __netdev_alloc_skb
[   10.619947] rtlwifi: Unknown symbol __netdev_alloc_skb (err -22)
[   10.619968] rtlwifi: disagrees about version of symbol skb_trim
[   10.619982] rtlwifi: Unknown symbol skb_trim (err -22)
[   10.620011] rtlwifi: disagrees about version of symbol wiphy_rfkill_start_polling
[   10.620025] rtlwifi: Unknown symbol wiphy_rfkill_start_polling (err -22)
[   10.620051] rtlwifi: disagrees about version of symbol freq_reg_info
[   10.620065] rtlwifi: Unknown symbol freq_reg_info (err -22)
[   10.620097] rtlwifi: disagrees about version of symbol rate_control_send_low
[   10.620111] rtlwifi: Unknown symbol rate_control_send_low (err -22)
[   10.620129] rtlwifi: disagrees about version of symbol ieee80211_unregister_hw
[   10.620143] rtlwifi: Unknown symbol ieee80211_unregister_hw (err -22)
[   10.620218] rtlwifi: disagrees about version of symbol ieee80211_rx_irqsafe
[   10.620232] rtlwifi: Unknown symbol ieee80211_rx_irqsafe (err -22)
[   10.633725] rtlwifi: disagrees about version of symbol skb_put
[   10.633760] rtlwifi: Unknown symbol skb_put (err -22)
[   10.633811] rtlwifi: disagrees about version of symbol skb_dequeue
[   10.633825] rtlwifi: Unknown symbol skb_dequeue (err -22)
[   10.633848] rtlwifi: disagrees about version of symbol ieee80211_free_hw
[   10.633861] rtlwifi: Unknown symbol ieee80211_free_hw (err -22)
[   10.633883] rtlwifi: disagrees about version of symbol ieee80211_alloc_hw
[   10.633895] rtlwifi: Unknown symbol ieee80211_alloc_hw (err -22)
[   10.633943] rtlwifi: disagrees about version of symbol regulatory_hint
[   10.633957] rtlwifi: Unknown symbol regulatory_hint (err -22)
[   10.633988] rtlwifi: disagrees about version of symbol ieee80211_register_hw
[   10.634001] rtlwifi: Unknown symbol ieee80211_register_hw (err -22)
[   10.634020] rtlwifi: disagrees about version of symbol ieee80211_rate_control_unregister
[   10.634034] rtlwifi: Unknown symbol ieee80211_rate_control_unregister (err -22)
[   10.634056] rtlwifi: disagrees about version of symbol ieee80211_get_hdrlen_from_skb
[   10.634069] rtlwifi: Unknown symbol ieee80211_get_hdrlen_from_skb (err -22)
[   10.634118] rtlwifi: disagrees about version of symbol kfree_skb
[   10.634131] rtlwifi: Unknown symbol kfree_skb (err -22)
[   10.634150] rtlwifi: disagrees about version of symbol ieee80211_tx_status_irqsafe
[   10.634162] rtlwifi: Unknown symbol ieee80211_tx_status_irqsafe (err -22)
[   10.634208] rtlwifi: disagrees about version of symbol wiphy_rfkill_set_hw_state
[   10.634222] rtlwifi: Unknown symbol wiphy_rfkill_set_hw_state (err -22)
[   10.634287] rtlwifi: disagrees about version of symbol dev_kfree_skb_irq
[   10.634300] rtlwifi: Unknown symbol dev_kfree_skb_irq (err -22)
[   10.634326] rtlwifi: disagrees about version of symbol wiphy_to_ieee80211_hw
[   10.634339] rtlwifi: Unknown symbol wiphy_to_ieee80211_hw (err -22)
[   10.634355] rtlwifi: disagrees about version of symbol dev_kfree_skb_any
[   10.634367] rtlwifi: Unknown symbol dev_kfree_skb_any (err -22)
[   10.634393] rtlwifi: disagrees about version of symbol wiphy_rfkill_stop_polling
[   10.634406] rtlwifi: Unknown symbol wiphy_rfkill_stop_polling (err -22)
[   10.634421] rtlwifi: disagrees about version of symbol skb_pull
[   10.634434] rtlwifi: Unknown symbol skb_pull (err -22)
[   10.634466] rtlwifi: disagrees about version of symbol wiphy_apply_custom_regulatory
[   10.634479] rtlwifi: Unknown symbol wiphy_apply_custom_regulatory (err -22)
[   10.634685] rtlwifi: disagrees about version of symbol ieee80211_rate_control_register
[   10.634704] rtlwifi: Unknown symbol ieee80211_rate_control_register (err -22)
[   10.634802] rtlwifi: disagrees about version of symbol __netdev_alloc_skb
[   10.634816] rtlwifi: Unknown symbol __netdev_alloc_skb (err -22)
[   10.634839] rtlwifi: disagrees about version of symbol skb_trim
[   10.634851] rtlwifi: Unknown symbol skb_trim (err -22)
[   10.634883] rtlwifi: disagrees about version of symbol wiphy_rfkill_start_polling
[   10.634896] rtlwifi: Unknown symbol wiphy_rfkill_start_polling (err -22)
[   10.634922] rtlwifi: disagrees about version of symbol freq_reg_info
[   10.634935] rtlwifi: Unknown symbol freq_reg_info (err -22)
[   10.634967] rtlwifi: disagrees about version of symbol rate_control_send_low
[   10.634980] rtlwifi: Unknown symbol rate_control_send_low (err -22)
[   10.634998] rtlwifi: disagrees about version of symbol ieee80211_unregister_hw
[   10.635011] rtlwifi: Unknown symbol ieee80211_unregister_hw (err -22)
[   10.635086] rtlwifi: disagrees about version of symbol ieee80211_rx_irqsafe
[   10.635099] rtlwifi: Unknown symbol ieee80211_rx_irqsafe (err -22)
[   20.613467] ip_tables: (C) 2000-2006 Netfilter Core Team
[   24.816143] net eth0: initializing cpsw version 1.12 (0)
[   24.818518] net eth0: phy found : id is : 0x7c0f1
[   24.818545] libphy: PHY 4a101000.mdio:01 not found
[   24.823608] net eth0: phy 4a101000.mdio:01 not found on slave 1
[   24.932474] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   27.896877] libphy: 4a101000.mdio:00 - Link is Up - 100/Full
[   27.896955] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Any idea ?
Thanks.
Posted: Tue Jul 01, 2014 7:56 pm
That is completely wierd.
It looks like there's some kind of problem in the USB stack.. the errors show the same general class of problems with the wifi dongle and what I'd guess is a bluetooth dongle.
The specifics are beyond me though.. you'll probably need to check on the BBB forums to see if anyone there knows what's going on: http://beagleboard.org/Community/Forums
If it turns out to be a hardware problem, the makers of the BBB are very specific about demanding to handle all returns themselves.
