flakey button
flakey button
by ihav2p on Sun Feb 17, 2008 6:29 pm
hello my kit is up and running, with only a tiny problem now. the run stop button is a bit flakey. when i leave a pattern running for 2 measures or so, i really need to hold the button for a long time to stop it. then when it stays off for awhile same thing. at any other times it is perfectly responsive. i checked the button legs, and i dont think there is a problem there, where should i look next? thanks for any help
ihav2p
by phono on Sun Feb 17, 2008 7:05 pm
its possible you damaged it while soldering (this is most likely)
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
by ihav2p on Mon Feb 18, 2008 3:59 am
hey phono thanks for the tip. i am a total newb, so be patient with me. but can it really be the switch? it works fine right on power up, and i can run it for awhile (like 3 min) before the switch starts showing problems. this is pretty consistent. if it were the switch wouldnt it always be inconsistent?
ihav2p
by phono on Mon Feb 18, 2008 7:08 am
of course it could be something else, but start with the obvious and work back, you could try reflowing the joints on the dodgy switch to see if that helps.
Also those tact switches really arent expensive, so its probably easiest to replace and see if that helps. If not then you have a more serious problem and should look deeper.
phono
by ihav2p on Mon Feb 18, 2008 8:51 am
hi phono, i have to wait awhile to be sure, but i think its fixed. i just reheated the joint on the IC side. seems i was going a bit too fast at the end. thanks again. :)
ihav2p
by phono on Mon Feb 18, 2008 12:28 pm
ihav2p wrote:hi phono, i have to wait awhile to be sure, but i think its fixed. i just reheated the joint on the IC side. seems i was going a bit too fast at the end. thanks again. :)
great 8)
phono
