VCO issue (solved)
VCO issue (solved)
by vlady on Sat Feb 23, 2008 5:12 pm
Just started the vco section and did the control voltage test. I'm getting 2.9V across the tab next to R81 (as shown in the build manual)and R90 but am not getting anything on pin7 of IC11. I am getting 2.9V on pin 5, but none of the other pins have any voltage. Any idea? I've checked all transistors, trim pots and. IC11 is socketed but I don't think that should make a difference.
vlady
by guest on Sun Feb 24, 2008 3:00 am
what are all the voltages on ic11
guest
by vlady on Sun Feb 24, 2008 1:36 pm
only pin with voltage is pin 5 since 2.9-3v
vlady
by guest on Sun Feb 24, 2008 3:24 pm
in which case the opamp isnt getting power
check to see that the ioboard is connected well
there should be 12v on pin8
guest
by vlady on Sun Feb 24, 2008 4:01 pm
I didn't know the i/o needed to powered up along with the cv, although now that I think about it, it makes perfect sence. Anyway, all checks out perfect with the i/o board powered up. 3.0v at pin 7. Thanks guest.
vlady
Re:
by EmptySet on Sun Jan 11, 2009 5:47 am
vlady wrote:I didn't know the i/o needed to powered up along with the cv
I ran into the same exact problem! The instructions are not clear that AC power needs to be reconnected to test the waveform.
EmptySet
Re: VCO issue (solved)
by strosek on Thu Aug 13, 2009 9:49 pm
I wasted 2 hours with the same problem &$&@
Would someone update the manual already! Please!!
What a bad way to start a project.
Thank you
strosek
by adafruit on Sun Aug 16, 2009 2:16 pm
the manual has been updated
cron
