right way to burn firmware ?
by janvanvolt on Wed May 28, 2008 12:45 pm
can anybody provide the rights steps on burning new/the firmware using a avr programmer ?
i got the option for EEPROM or FLASH on the 162 CPU burner, so what needs to go where ?
janvanvolt
by guest on Wed May 28, 2008 11:46 pm
the program goes in the flash
i dont think anything goes in the eeprom
you need to set the fuse bits correctly
there should be a post somewhere
with the correct settings
guest
by janvanvolt on Thu May 29, 2008 3:21 pm
i searched all archives forth and back and do not find a info about the right fuse settings.
anybody else able to assist me ?
janvanvolt
by guest on Thu May 29, 2008 7:05 pm
it took some digging
but here is the information
its always frustrating how much useful info
gets lost forever in these forums
the following fuses are set
and anything else is not set
brown out detection at 4.3v
preserve eeprom through chip erase cycle
boot size equals 256
boot reset vector enabled
external oscillator greater than 8mhz 16k clock plus 65ms
guest
by janvanvolt on Thu May 29, 2008 9:12 pm
Thank you for the excellent information. My x0xb0x is now reachable by USB as well as fully functional (some other issues, will do seperate thread).
i will write down the fuse settings and publish on my blog as well.
many many thanks "guest" !
##THREAD CLOSED##
janvanvolt
by phono on Fri May 30, 2008 3:31 am
guest wrote:its always frustrating how much useful info
thats why i just added this to the troubleshooting faq, will also try to add any other useful tidbits that surface in time :)
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
by janvanvolt on Sun Jun 08, 2008 6:25 pm
My x0x is now working. I received the original firmware from Ladyada last saturday and after putting it in, all works fine. So i assume i did something wrong with the fuses. I will check this later this week.
janvanvolt
Re: right way to burn firmware ?
by Sasha on Sun Oct 26, 2008 4:56 am
I finished my box but having trouble with chip.
I`m using usbtiny.
Burning the chip passed OK, but after instaling the chip, sequencer acts like it is partially working and at the wrong speed. I figured out it must be the fuses.
I calculated fuses for atmega162 acording to guest info:
so the result from calculator was this: http://www.engbedded.com/cgi-bin/fc.cgi ... _BOOTRST=P
After I tried to wright any of following fuses I get The system cannot find the file specified
avrdude -c usbtiny -p atmega162 -U lfuse:w:<0xFD>:m
avrdude -c usbtiny -p atmega162 -U hfuse:w:<0xB4>:m
avrdude -c usbtiny -p atmega162 -U efuse:w:<0xF9>:m
Are the fuses locked somehow or am I doing something wrong?
Sasha
by Sasha on Wed Nov 12, 2008 4:35 am
Problem with fuses solved. (It takes external crystal to burn the all fuses.)
Sasha
