Motor Shield
Motor Shield
by jimcook on Mon Sep 01, 2008 4:34 pm
Everything worked well with the program in the Shield manual that runs the stepper motor.
My problem has been trying to get the program for a DC motor. It mentions that AFMotor.h should be included. The program does have a line that says: #include <AFMotor.h>.
When I try to compile I get an error message that includes:" :21: error: AFMotor.h: No such file or directory in function 'void setup()': In function 'void loop()': "
Can someone please translate?
jimcook
by adafruit on Mon Sep 01, 2008 5:31 pm
sounds like you didnt install the library
by jimcook on Mon Sep 01, 2008 5:40 pm
Where is the best place to look for how to "install the library" and where is the "library" I should install?
I do see "AFMotorlibv2" folder that has a folder called "AFmotor" that holds "AFLotor.cpp" and "AFMotor.h". So I think I down loaded the proper files. My original question still stands. How do I "install" them?
ladyada wrote:sounds like you didnt install the library
jimcook
by adafruit on Mon Sep 01, 2008 7:36 pm
http://www.ladyada.net/make/mshield/download.html
"Arduino Stepper/Servo software library v2. Uncompress and stick the AFMotor directory into the Arduino/hardware/library folder."
by jimcook on Mon Sep 01, 2008 8:13 pm
GREAT! So simple I was overlooking it. It works. Thankyou very much.
ladyada wrote:http://www.ladyada.net/make/mshield/download.html
jimcook
Intel Mac : 21: error: AFMotor.h: No such file or directory.
by buildingscience on Tue Sep 01, 2009 7:23 pm
I installed the latest arduino software and when i downloaded it, there was no "hardware" folder created when the disc image was mounted on my desktop. I am using an Intel mac.
So i created a folder "Arduino" and put the arduino application in it. Inside "Arduino" i also created a "hardware" folder and a "library" folder within "hardware". Then i placed the "AFMotor" directory inside of "library"
I opened the motorTest.pde and got the following error when i verified the code
21: error: AFMotor.h: No such file or directory In function 'void setup()':
Can someone explain why the arduino software can not locate AFMotor.h?
What seems strange is that i had to create the hardware folder, which is not mentioned as necessary in any of the earlier posts.
-thanks
buildingscience
Re: Motor Shield
by buildingscience on Tue Sep 01, 2009 7:58 pm
ok, i saw this note and now i have the test running....
http://arduino.cc/blog/?p=313
no need to respond to this
buildingscience
