Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more. Accepting essential orders - here's how.
STOP THE MADNESS: How to use the drill guide
by darco on Wed Nov 19, 2008 4:07 pm
Alright, I've seen too many ybox2 tins made *backward*, and it's driving me *crazy*.
You know the drill guide? Yeah, this one. It's designed to be cut out, and then taped to the *bottom* of the tin. You then drill right thru it. Just like in these pics:
And then, when you are done, it looks like this:
Doesn't that look better? You can see all of the pictures here.
I hope this helps save a few mangled tins.
darco
Re: STOP THE MADNESS: How to use the drill guide
by adafruit on Wed Nov 19, 2008 11:06 pm
take deeeep breaths...
i'll add this to the assembly guide!
:lol:
by darco on Thu Nov 20, 2008 3:01 pm
^_^
darco
by psyicman on Mon Jan 26, 2009 1:21 am
The pictures alone were good enough to get an idea how to drill out the tin. The only thing you need to do is go slow when drilling them and to make sure the guid is on properly and tight. I went through 2 tins. I got a little over eagear and tore one up and I did not like the way the other came out.
My parents told me I could be anything I wanted to be when I grew up. I choose Ninja.
It's a rat flail!
psyicman
by E_Don on Mon Jun 08, 2009 12:06 am
huh....too bad i didnt read this before i cut the tin =/, haha was wondering why it looked messed up
E_Don
by gunterhausfrau on Mon Sep 21, 2009 11:00 pm
something is amiss. Either the tins have gotten smaller, the ethernet ports have gotten bigger or I am missing something. The plug I have is too big not to cut the lid. I don't have a problem with that, but it doesn't look like the one in the picture it was necessary. Am I missing something? I have lots of tins to play with, so I am not worried about messing a few up, but I would like to understand the disconnect.
thanks.
gunterhausfrau
by darco on Tue Sep 22, 2009 5:42 pm
If the bottom of the tin doesn't match up exactly with the outline on the guide, then it is likely being scaled inappropriately when you are printing it.
Make sure that "fit to page" is turned off when you try to print the drill guide.
darco
by gunterhausfrau on Fri Sep 25, 2009 3:22 pm
not so much the drill guide, but the actual size of the ethernet port.
gunterhausfrau
by darco on Mon Sep 28, 2009 3:37 pm
Oh! Sorry, I misunderstood.
I have always had the same issue you described. It is easily solved by bending the lip of the lid out slightly with your thumb. It will then fit quite nicely. That's what I did in the photos.
You can see me doing this in the following three photos:
http://www.deepdarc.com/module/album/view/1304
http://www.deepdarc.com/module/album/view/1305
http://www.deepdarc.com/module/album/view/1306
darco
by reubanks on Mon May 24, 2010 1:33 pm
But why do both ThinkGeek AND LadyAda have incorrect pics on their pages?
reubanks
by darco on Mon May 24, 2010 3:02 pm
Because they didn't want to make a new tin just to take a few pictures.
I don't blame them.
darco
by reubanks on Mon May 24, 2010 5:42 pm
darco wrote:Because they didn't want to make a new tin just to take a few pictures.
I don't blame them.
Yeah, but how hard is it to take one of the correct pictures floating around and swap them? (Having an incorrect picture on the pages where most people order the kits MAY be why there are so many backwards YBoxen out there.)
Just a thought.
Randy
reubanks
by Tooliktman^ on Tue Jul 06, 2010 4:37 am
Hi, Can i know the name and the measure of the drill tip you have used. And for what kind of material? :?:
Tooliktman^
by jrv on Fri Jun 14, 2013 1:51 pm
darco wrote:You know the drill guide? Yeah, this one.
I was getting "server not found" errors on this. Contacted darco about it and he pointed me to the drill guide on github.
jrv
by jrv on Fri Jun 14, 2013 2:00 pm
LadaAda's instructions also refer to the broken link.
jrv
