Bluefruit exit from Beacon mode
- alpesh2559
hi..i use adafruit bluefruit LE (UART friend) with arduino protrinket board to control using android app to colour of neopixel using colour picker..i succefully work on app controller mode and able to change colour of neo pixel but one time i unfortunatly select beacon mode of app...so how to exit from becon mode of app...i uninstall app and reinstall so its still on beacon mode...i want to switch in controller mode....
Re: Bluefruit exit from Beacon mode
You can reset the unit to its original condition by connecting the DFU pin to GND for more than 5 seconds:
https://learn.adafruit.com/introducing- ... ia-dfu-pin
- alpesh2559
but here issue in android app not in hardware undestand...app is run in becone mode continue if i uninstall and again reinstall than its open time continue show in becone mode
- alpesh2559
i want to sitch over from becone mode to controller mode in android app...
You should be able to choose 'Disconnect' in the app, then reconnect. When you do, the app should give you a list of ways you can connect to the device.
