strange things with the 5.333V
by substyler on Sun Dec 14, 2008 5:38 pm
hi !
i have just finished my first (self sourced) x0xb0x and after some trouble with some faulty transistors everything works fine.
BUT: my x0x have still some trouble with the 5.333V: when I trim to 5.333V my x0x plays with filter warble and some dropouts and IC23 on the power supply is going to be very hot.
when I turn down the 5.33V to 5.15V (measured at J4) the x0x is working very fine ! no dropouts, no filter warble and IC23 stays cool.
turning with TM6 back to 5.333V the x0x play that dropouts and the filter warble (sounds liquid or something)
I double and triple checked all wires, all traces, but I can't find any problems.
this makes me mad :x
every hint would be really helpful !
thanks in advance !
cheers
SubStyler
electronics consists to 80% of superstition and to 20% of fairy tales • DIY or die!
substyler
Re: strange things with the 5.333V
by guest on Mon Dec 15, 2008 10:18 am
what is your 12v voltage
with 5.333v and 5.15v
you can disconnect the 12v line to the mainboard
and then turn up the 5.333v and see if it overheats
and then reconnect the 12v and disconnect the 5.333 line to the mainboard
and turn up the the 5.333v and see if it overheats
there might be a part on the mainboard that cant handle 5.333v
check the 74ac174 to see if it heats up when you turn up the 5.333v
or feel around for other parts that might also be getting hot
what is your voltage on c8
guest
by substyler on Sat Dec 20, 2008 1:08 pm
hey guest,
IC 9 was faulty ! I'm getting a new one, everything is working fine ! ( it was a good idea to socket all ICs :) )
no more heat, no more warble... only acid !
good job, thnx :)
cheers
SubStyler
substyler
by phono on Sat Dec 20, 2008 1:52 pm
added to faq
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
