BNO055
Post test messages here
hans1
BNO055
Post by hans1 »
I am using your BNO055 with the sketch restore_offsets and the arduino UNO.This is working fine.
My plan is to build an autopilot for my boat so I need to read the course in a variable. That is where I fail.
I create a float course and assign that to event.orientation.x. Serial.print(course) gives me 0 while writing to LCD
with lcd.print(event.orientation.x,0) gives correct number.
I sent part of the code.
Thank you very much for any respons.
adafruit_support_rick
Re: BNO055
Post by adafruit_support_rick »
Please post your entire sketch, and please post the Serial Monitor output from the sketch
hans1
Re: BNO055
Post by hans1 »
Thank you for your respons, I posted the complete sketch but I still have to find out how to include the monitor output as that is continuously going on.
I feel not too bright.
restore_offsets-160306a.zip
(2.62 KiB) Downloaded 254 times
Re: BNO055
Un-check the Auto Scroll box in the lower left of the Serial Monitor window. Then run your sketch
Re: BNO055
I don't know how this statement compiles successfully. But it's wrong.
     mv=(event.orientation.x,0);
You want to do this:
    sensors_event_t event;
    bno.getEvent(&event);
    float mv;// Also tried double and int
    mv = event.orientation.x;
   /*  Display the floating point data */
    Serial.print("koers: ");
    // Serial.print((float)event.orientation.x,0);
   Serial.print(mv, 4);
hans1
Re: BNO055
Post by hans1 »
It is allright now, thank you very much.
In case you are still interesred in the output, I sent it hereby.
putty.log
(5.13 KiB) Downloaded 356 times
Re: BNO055
Great!
Return to “Test Message Forum (closed)”
