I recently purchased a Raspberry Pi 3 Model B starter pack. When I received it, I tried it out with the micro SD card that came in the package with Noobs v1.8 preloaded on it. The display was a colorful screen when it booted up, so I waited a few minutes to see if anything would change. When the screen stayed the same, I decided to format the micro SD card thinking it may have been a corrupt OS.
I placed the micro SD card in the SD card adapter so I could use the SD card slot on my laptop. The first thing I tried was using fdisk on Ubuntu to clear the partitions and start fresh. fdisk claimed the partitions were removed, but after fdisk completed, the partitions were still there. I then tried using dd, parted, and maybe a couple other utilities, but nothing seemed to reformat the card. I tried toggling the lock on the SD card adapter to verify the hardware lock wasn't enabled. I have a USB micro/SD card reader (it has two slots for micro and regular SD card), but that didn't work either. I tried utilities in Windows including diskpart, SDformatter, and setting a write enabled flag in the registry, but nothing was working. I tried the card out on a Macbook, but that didn't work either. I even tried sticking the card in a camera to format it, but the camera claimed the card was locked! (I made sure to toggle the hardware switch)
I've exhausted all of the resources I know of as far as formatting this card that came with the Raspberry Pi 3 starter pack. Any suggestions?
Thank you!
Write Protected SD Card
- Rgissing
Re: Write Protected SD Card
I am also having this problem too. it seemed pretty obvious that i just install it and turn it on, but it did not work. I looked at the files on it my laptop and the files are there but it would boot. any suggestions would be great. I am sure that the sd card is ok.
- chanjp
I am encountering the same issue. Are we just unlucky enough to get corrupted SD cards? And on my first attempt at the Raspberry Pi as well!
- chanjp
I am definitely sure I was given a broken SD Card. I can't even update the OS properly when I borrowed a friend's Pi 2 (which can run the SD card.
Here's the output:
Here's the output:
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main perl armhf 5.20.2-3+deb8u4 [2068 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main perl-base armhf 5.20.2-3+deb8u4 [1097 kB]
Fetched 3165 kB in 6s (521 kB/s)
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "en_US.UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
E: Corrupted archive
E: Prior errors apply to /var/cache/apt/archives/libc6_2.19-18+deb8u3_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libapt-pkg4.12_1.0.9.8.2_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/apt_1.0.9.8.2_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libpcre3_2%3a8.35-3.3+deb8u2_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libudev1_215-17+deb8u3_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/udev_215-17+deb8u3_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libpam0g_1.1.8-3.1+deb8u1_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libpam-modules-bin_1.1.8-3.1+deb8u1_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libpam-modules_1.1.8-3.1+deb8u1_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libgcrypt20_1.6.3-2+deb8u1_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libsystemd0_215-17+deb8u3_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libpam-systemd_215-17+deb8u3_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/systemd_215-17+deb8u3_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/systemd-sysv_215-17+deb8u3_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libpam-runtime_1.1.8-3.1+deb8u1_all.deb
E: Prior errors apply to /var/cache/apt/archives/libapt-inst1.5_1.0.9.8.2_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libssl1.0.0_1.0.1k-3+deb8u4_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libgssapi-krb5-2_1.12.1+dfsg-19+deb8u2_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libkrb5-3_1.12.1+dfsg-19+deb8u2_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libkrb5support0_1.12.1+dfsg-19+deb8u2_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/BANNED_1.12.1+dfsg-19+deb8u2_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/file_1%3a5.22+15-2+deb8u1_armhf.deb
E: Prior errors apply to /var/cache/apt/archives/libmagic1_1%3a5.22+15-2+deb8u1_armhf.deb
debconf: apt-extracttemplates failed: No such file or directory
Extracting templates from packages: 100%
Preconfiguring packages ...
(Reading database ... 116795 files and directories currently installed.)
Preparing to unpack .../perl_5.20.2-3+deb8u4_armhf.deb ...
Unpacking perl (5.20.2-3+deb8u4) over (5.20.2-3+deb8u1) ...
Preparing to unpack .../perl-base_5.20.2-3+deb8u4_armhf.deb ...
Unpacking perl-base (5.20.2-3+deb8u4) over (5.20.2-3+deb8u1) ...
Processing triggers for man-db (2.7.0.2-5) ...
Setting up perl-base (5.20.2-3+deb8u4) ...
Preparing to unpack .../perl-modules_5.20.2-3+deb8u4_all.deb ...
Unpacking perl-modules (5.20.2-3+deb8u4) over (5.20.2-3+deb8u1) ...
dpkg-deb (subprocess): decompressing archive member: lzma error: compressed data is corrupt
dpkg-deb: error: subprocess <decompress> returned error exit status 2
dpkg: error processing archive /var/cache/apt/archives/perl-modules_5.20.2-3+deb8u4_all.deb (--unpack):
cannot copy extracted data for './usr/share/doc/perl-modules/changelog.Debian.gz' to '/usr/share/doc/perl-modules/changelog.Debian.gz.dpkg-new': unexpected end of file or stream
Preparing to unpack .../libc6-dev_2.19-18+deb8u3_armhf.deb ...
Unpacking libc6-dev:armhf (2.19-18+deb8u3) over (2.19-18+deb8u1) ...
dpkg: error processing archive /var/cache/apt/archives/libc6-dev_2.19-18+deb8u3_armhf.deb (--unpack):
cannot copy extracted data for './usr/lib/arm-linux-gnueabihf/libpthread.a' to '/usr/lib/arm-linux-gnueabihf/libpthread.a.dpkg-new': unexpected end of file or stream
Preparing to unpack .../libc-dev-bin_2.19-18+deb8u3_armhf.deb ...
Unpacking libc-dev-bin (2.19-18+deb8u3) over (2.19-18+deb8u1) ...
dpkg: error processing archive /var/cache/apt/archives/libc-dev-bin_2.19-18+deb8u3_armhf.deb (--unpack):
cannot copy extracted data for './usr/bin/rpcgen' to '/usr/bin/rpcgen.dpkg-new': unexpected end of file or stream
Preparing to unpack .../libc-bin_2.19-18+deb8u3_armhf.deb ...
Unpacking libc-bin (2.19-18+deb8u3) over (2.19-18+deb8u1) ...
dpkg-deb (subprocess): decompressing archive member: internal gzip read error: '<fd:4>: invalid block type'
dpkg: error processing archive /var/cache/apt/archives/libc-bin_2.19-18+deb8u3_armhf.deb (--unpack):
cannot copy extracted data for './usr/lib/locale/C.UTF-8/LC_COLLATE' to '/usr/lib/locale/C.UTF-8/LC_COLLATE.dpkg-new': unexpected end of file or stream
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
- Rgissing
I agree. My card they shipped me cannot be formatted in any formated. . Ugh. Shipping stuff back is going to really suck.
Don't worry about sending anything back. Let's just replace the cards.
@jdellaire, Rgissing, & chanjp: Send notes to [email protected] with a link to this thread and the folks there will get you new SD cards.
- Rgissing
you guys are groovy!!! thanks
- adafruit2
hey ya'll can you post photos of your cards? if you plug them into a computer do you see the noobs files? kinda weird error!
- Rgissing
i can do that tonight, but it is a wierd error because the SD card can is readable, and it will boot in a pi 2 to raspian , i do not think it actually has noobs on it. i will send picture soon.
robert
robert
- adafruit2
ok yah any screenshots of the sd card contents would be (thumbsup)
- jdellaire
Here are the 2 partitions on the SD card with Noobs preloaded on it that came with the starter pack:
As root, I can touch a file on either partition, modify files, etc. When I umount the partitions then re-mount them, any files I added are removed, and modified files are back to what they originally were. I have also toggled with switch on the adapter many times as well.
-jdellaire
-jdellaire
- jdellaire
Here is an example of using fdisk to try and clear the partitions on the SD card:
As you can see, I tried to clear the two partitions then create a single partition on the card, but the original parititons stay on the card.
-jdellaire
-jdellaire
- solmar
order number: 1035253-8269502337
product ordered:Raspberry Pi 3 Model B Starter Pack - Includes a Raspberry Pi 3[ID:3058]
failed product within kit: 8GB SD card for Raspberry Pi preinstalled with Noobs v1.8 - 8GB microSD [ID:1583]
problem: write protected SD card . It wont boot in Pi, it's stuck on the rainbow screen.
troubleshooting:i attempted to format it with “SDFormatter”, but it fails to format because it’s write locked.
solution: I purchased a 16GB SanDisk micro SD card and was able to format it with SDFormatter and copied the noobs v1.8 files content to it and the PI was able to boot.
- 20160315_155155_resized.jpg (627.5 KiB) Viewed 3113 times
- adafruit2
OK we had a batch of corrupted cards - which is odd but we made new ones up and i tested a few and they boot fine
plz email support@adafruit and ask for a new card, they'll send it to you :)
- pedersenit
I have a similar issue on the Raspbian Jessie 8GB card that I just received. It boots, but i can't do anything, it keeps telling me that there is no more room. I try to expand the filesystem, but it fails. I have even tried to reformat it on several computers. Order #1051830-0382177438
