Do I have the right hardware?
Post test messages here
odonohoe
Post by odonohoe »
I am an educator but a total beginner in electronics and programing sketches. I am working with 6th graders. They have designed a mechanism which requires 2 stepper motors to run backward or forward in response to separate push button switches. They are also using a servo controlled by a potentiometer/joystick. I have a MEGA 2560, 2 NEMA 17 12v 200x #324stepper motors, 1 hitec HS-311 servo and an adafruit Motorshield V-2.3 to drive the steppers. Do I need something else to drive the servo? If so what? Will these components work alright together or would you suggest something else? Please reply as soon as you can . thanks
Franklin97355
Re: Do I have the right hardware?
Post by Franklin97355 »
The servo can be driven through the Motor shield but you need to have power for the steppers and servo.
odonohoe
Post by odonohoe »
How would I best supply the power? Do I need separate battery packs for each motor? How many volts should be supplied? thanks franklin97355 for the speedy reply.
Franklin97355
You should have 12 volts for the steppers and less than 6 for the servo. the servo could run from the Mega but the steppers should be powered from the connections on the shield. Take a look at this guide on Stepper Motors
Return to “Test Message Forum (closed)”
