Exterior lighting ideas
ebeyer
Post by ebeyer »
I'm increasingly dissatisfied with my front porch lighting - solar stem lights whose stems like to break, making them look like glowing fallen trees after a hurricane. I need something durable, mostly weather-proof that's easy to set up (relatively) and hard to accidentally destroy (eg., my lawn mower). I was thinking of maybe running neopixel strips down my front walk (~20 feet on either side, so maybe 40-50 feet total?) or 10-12 charliepixel matrix units placed strategically, similar to what I'm doing with the solar lights right now.
The plan would be to route power from a solar battery I have at the front of the house and to set up the lights to either come on at a specific time or to use a light sensor or somesuch.
Has anyone attempted anything like this? What has been your experience? Any advice?
Thanks in advance.
Re: Exterior lighting ideas
[Moved from Test Messsages -> Glowy Things forum]
The strips have a waterproof sheath, but the ends and any splices will need to be sealed. The other Neopixel products are not waterproof, so you would need to find or make a suitable enclosure. The solar garden lights would make a good housing for a Neopixel ring.
For the solar garden lights, I just throw away the plastic spikes. I cut an 18" length of steel pipe - slightly smaller than the ID of the stems. Drive the pipe into the ground and slip the stem of the solar light over the pipe. No more broken stems.
