Hey, So I've made the midi glove, and im pretty sure all my connections are solid.
When i go to upload the code, im getting error messsages in arduino telling me that parts of the code are not declared in this scope.
For example, 'thumb' not declared in this scope
its happening for multiple fingers, as well as 'usbmidi' not declared in this scope.
What should I do ?
Midi Glove Arduino Code
- Franklin97355
Re: Midi Glove Arduino Code
Post your code here and make sure you have all the libraries needed and installed in the correct locations. Also post the output of the errors.
- handle1012
Piezo Keyboard glove
products from Adafruit!
Written by Limor Fried & Becky Stern for Adafruit Industries.
BSD license, all text above must be included in any redistribution
const int indexFinger = A9; // the piezo is connected to analog pin 9 (aka D9)
const int middleFinger = A7; // the piezo is connected to analog pin 7 (aka D6)
const int thumb = A10; // the piezo is connected to analog pin 10 (aka D10)
const int pinkyFinger = A11; // the piezo is connected to analog pin 11 (aka D12)
const int pins[] = {thumb, indexFinger, middleFinger, pinkyFinger};
char Keys[] = {'z','x','c','v'};
boolean currentPressed[] = {false, false, false, false};
const int threshold = 40; // threshold value to decide when the detected sound is a knock or not
void setup()
//while (!Serial)
Serial.begin(115200);
Serial.println("start");
Keyboard.begin();
void loop()
for (int i=0;i<4;i++) {
delay(1);
long total1 = 0;
long start = millis();
long total = analogRead(pins);
// check if we are sensing that a finger is touching
// and that it wasnt already pressed
if ((total > threshold) && (! currentPressed)) {
Serial.print("Key pressed #"); Serial.print(i);
Serial.print(" ("); Serial.print(Keys); Serial.println(")");
currentPressed = true;
Keyboard.press(Keys);
else if ((total <= threshold) && (currentPressed)) {
// key was released (no touch, and it was pressed before)
Serial.print("Key released #"); Serial.print(i);
currentPressed = false;
Keyboard.release(Keys);
delay(5);
Thats the code that instruction manual gave me, and here is the error message.
Arduino: 1.6.7 (Windows 10), TD: 1.27, Board: "Arduino/Genuino Uno"
sketch_apr05a:12: error: 'A9' was not declared in this scope
sketch_apr05a:14: error: 'A10' was not declared in this scope
sketch_apr05a:15: error: 'A11' was not declared in this scope
C:\Users\Steve\BANNED\Documents\Arduino\sketch_apr05a\sketch_apr05a.ino: In function 'void setup()':
sketch_apr05a:30: error: 'Keyboard' not found. Does your sketch include the line '#include <Keyboard.h>'?
Keyboard.begin();
C:\Users\Steve\BANNED\Documents\Arduino\sketch_apr05a\sketch_apr05a.ino: In function 'void loop()':
sketch_apr05a:49: error: 'Keyboard' not found. Does your sketch include the line '#include <Keyboard.h>'?
sketch_apr05a:57: error: 'Keyboard' not found. Does your sketch include the line '#include <Keyboard.h>'?
Keyboard.release(Keys[i]);
sketch_apr05a:62: error: redefinition of 'void setup()'
}void setup() {
sketch_apr05a:25: error: 'void setup()' previously defined here
void setup()
sketch_apr05a:67: error: redefinition of 'void loop()'
sketch_apr05a:34: error: 'void loop()' previously defined here
void loop()
exit status 1
enabled in File > Preferences.
Also, given their instructions its very unclear as to what I need to have downloaded and installed in terms of libraries.
I'm not complaining, because I'm pretty sure I did it correctly, but I cant be sure.
void setup()
//while (!Serial)
Keyboard.begin();
void loop()
delay(1);
long total1 = 0;
delay(5);
Keyboard.begin();
}void setup() {
void setup()
void loop()
exit status 1
- handle1012
That isnt the initial error message I was talking about. Ugh, I'm all messed up here!
- adafruit2
you have to use the flora in teeonardu mode
https://learn.adafruit.com/atmega32u4-b ... eensyduino
but use Flora teensy as the board type
