Flora issue when compiling
Post test messages here
seba8282
Post by seba8282 »
Hello!
I'm brand new around here. I was testing my new Flora, followed the installation guides and all looks good, except that when I try to upload the blinking led code to my Flora, I get:
Arduino: 1.6.9 Hourly Build 2016/04/06 06:33 (Windows 10), Board: "Adafruit Flora"
C:\Users\test\Desktop\arduino-nightly\hardware\arduino\avr\cores\arduino\CDC.cpp: In function 'bool CDC_Setup(USBSetup&)':
C:\Users\test\Desktop\arduino-nightly\hardware\arduino\avr\cores\arduino\CDC.cpp:104:29: error: 'MAGIC_KEY_POS' was not declared in this scope
uint16_t magic_key_pos = MAGIC_KEY_POS;
C:\Users\test\Desktop\arduino-nightly\hardware\arduino\avr\cores\arduino\CDC.cpp:129:34: error: 'MAGIC_KEY' was not declared in this scope
*(uint16_t *)magic_key_pos = MAGIC_KEY;
exit status 1
Error compiling for board Adafruit Flora.
I tried commenting the lines in the CDC.cpp file, but I get new errors, so I figure I just leave it as it is and ask here. Any clue on how to solve it?
I really appreciate it!
Seba
Franklin97355
Re: Flora issue when compiling
Post by Franklin97355 »
Try using 1.6.5 or 1.6.7 the error looks like it is coming from the compiler and not your program.
ericfoster
Post by ericfoster »
I am having the same difficulty with a Feather 32u4. I have tried IDE 1.6.9, 1.6.8, 1.6.7, 1.6.5r5...all running on Mac OS 10.10.5. Can you help? This is the error message:
...Arduino15/packages/arduino/hardware/avr/1.6.11/cores/arduino/CDC.cpp: In function 'bool CDC_Setup(USBSetup&)':
...Arduino15/packages/arduino/hardware/avr/1.6.11/cores/arduino/CDC.cpp:104:29: error: 'MAGIC_KEY_POS' was not declared in this scope
...Arduino15/packages/arduino/hardware/avr/1.6.11/cores/arduino/CDC.cpp:129:34: error: 'MAGIC_KEY' was not declared in this scope
Error compiling.
Franklin97355
Make sure you have the latest versions of the Adafruit boards installed and if that does not help sometimes deleting the Arduino15 folder completely (while the IDE is closed.) helps. Restart the IDE after removing the folder and try again.
ericfoster
Success after deleting Arduino15 and reimporting. Thank you.
Return to “Test Message Forum (closed)”
