I purchased three "ADXL377 - High-G Triple-Axis Accelerometer (+-200g Analog Out)" evaluation boards but am running into the same problem. All three seem to be outputting a constant voltage of 1.65V for the x, y and z axis when I measure them with my multimeter. Why do these voltages not change when the accelerometer is moved?
When I measure output voltages with my ADXL337 evaluation board, the x, y and z axis have varying voltages which I can then plug into an Excel file to determine the current angle for the x, y and z axis.
ADXL377 Voltage Output Voltage
Re: ADXL377 Voltage Output Voltage
Please post photos showing your soldering and connections to the boards.
- wickedhurricane
Attached is photo showing soldering and connection to an Arduino.
x connected to A0
y connected to A1
z connected to A2
ground to ground
Vin to 5V
Although I have tried various power and AREF combinations.
*I realize in the picture that y is connected to A2 and z to A1, but that is not the case.
x connected to A0
y connected to A1
z connected to A2
ground to ground
Vin to 5V
- IMG_0066.JPG (997.5 KiB) Viewed 3628 times
What range of raw values do you see in your Arduino output while moving the breadboard on the desk?
The 337 is a +/- 3G device. The 377 is a +/- 200G device. You need a much much stronger acceleration to register on the 377.
- wickedhurricane
Without measuring the raw values I think you answered my question.
I wanted to measure the angle of a swaying pendulum which might not supply enough G's.
What applications is the 377 typically used for?
And what is the difference between the ADXL335 and ADXL337?
The 377 is commonly used in high-impact applications such as drop or impact testing.
The 335 and 337 have similar specs. I think that the 337 is a later design and consumes a bit less power.
