Is it possible to get the firmware for the "Adafruit Bluefruit LE SPI Friend" - Board in the form of a hex file?
That would be the firmware of the nRF51822 chip from Nordic Semiconductor.
Best regards
Josh
Hex File of the "Adafruit Bluefruit LE SPI Friend" - Board
- Josh567
- drewfustini
Re: Hex File of the "Adafruit Bluefruit LE SPI Friend" - Boa
It is located here:
adafruit/Adafruit_BluefruitLE_Firmware
Firmware images for Adafruit's Bluefruit LE Modules (Bluefruit LE Friend, etc.)
Look for:
Bluefruit LE SPI Friend (BLESPIFRIEND Firmware)
Look for:
- Josh567
Thanks for the fast reply!
Now I took this file:
https://github.com/adafruit/Adafruit_Bl ... friend.hex
After I downloaded it, the device was not visible on the mobile phone.
Normally it should be visible in the "Bluefruit LE" - App...
Is this the right file?
Best regards
Josh
Best regards
Josh
- drewfustini
Please see this tutorial page:
Introducing the Adafruit Bluefruit LE SPI Friend: BLEUart
The BLEUart example sketch allows you to send and receive text data between the Arduino and a connected Bluetooth Low Energy Central device on the other end (such as you mobile phone using the Adafruit Bluefruit LE Connect application for Android or iOS in UART mode).
- Josh567
I found now another solution.
But thanks anyway!
Best regards
Josh
But thanks anyway!
Best regards
Josh
