I just received my order that included a Pimoroni Raspberry Pi 7" Touchscreen Display case.
Two of the pieces are broken but the box shows no major indication of crush or other damage.
How do I get this product replaced?
Damaged Item Received
- jcargile
- Box-2.png (667.04 KiB) Viewed 2580 times
- Box-1.png (661.5 KiB) Viewed 2580 times
- Frame.png (547.15 KiB) Viewed 2580 times
- Franklin97355
Re: Damaged Item Received
Please contact [email protected] with a link to this thread and they will help you
- jim_chaseandscout
This seems to be the place to post about having received damaged products...
Invoice 1109084
I just received the octoprint “package” today and I believe that the Realtek
Wifi dongle (#814B) is defective.
After fiddling with several software based solutions (config, updates, re-installs, etc),
I actually determined that it’s a hardware defect. If I don’t insert the dongle completely
(i.e., so that it doesn’t seat all the way in) and I wiggle it ever so slightly, the dongle
is detected by the system 50% of the time. I tried all four USB ports on the board.
And I have duplicated this behavior on my MacBook Air.
I'm pretty sure the dongle is bad.
Additionally, and possibly related, the dongle's metal shield gets quite hot when
plugged in.
Invoice 1109084
plugged in.
- Franklin97355
Jim, in order to keep things straight please start your own thread so we can give you individual support.
- AntarcticBear
I cannot create a topic on Administrative (cannot find POST button), and post this as a reply here.
I got the item same one of jcargile got.
Its third layer was broken.
And stands of it have different thickness, the one is about 6mm, other is 7mm.
So, I cannot insert hooks of 7mm stand into rectangular holes of 3rd and 4th layers.
I also checked the package box, but it looks that has no damage.
Can I get this product has no problem?
- Franklin97355
@Antarcticbear Please contact [email protected] with a link to this thread and they will help you
- PiGamerDesign
I also cannot find a post button to start my own thread, so I will reply here.
Problem: Defective product, DOA, however you want to categorize it since technically it doesn't work as intended.
Order number: 1073725-2429181348
Product ID: 2397
This screen arrived in the mail, beautifully packaged. As soon as I plugged it up, nothing happened. Not my first rodeo, so I started checking cable connections and found that if I hold the ribbon cable from the driver board to the screen a certain way, it would come up. I hot glued a thin layer under the cable and adhered it to the back of the screen.
Today, the screen would not come on. I moved that cable every which way. Eventually it would come on when I "pinch" a certain area of the ribbon cable, although it doesn't come on every time. Definitely a defective ribbon cable. I need to get this product replaced. Thank you for your support.
Product ID: 2397
- adafruit_support_rick
Have you checked that the ribbon cable is locked down in the connector?
We have closed the administrative forum to new posts. Please post in the appropriate product forum. If you tack onto existing threads, we may miss your post.
