PowerBoost 1000C Dead after 1 Day Use
- hybridsix
I had purchased 10 power boost 1000c units, and have had one fail after just a little more than a single day of use. I was powering the unit from the dual 18650 pack that Adafruit sells, to power a trinket and a neopixel ring. The unit no longer will output power, but the charge indicator light will still come on. I'd like to see about getting a replacement process started if possible.
- Franklin97355
Re: PowerBoost 1000C Dead after 1 Day Use
Can you post a picture of the unit and if you can the input and output voltage readings?
